Hi, this is my first time building PC so I'm very new to this and unfamiliar with a lot of stuff. I believe I have all the parts and wondering what else I need, any suggestions, etc. planning on reusing some of my current parts!! I'm open to buying parts if I need to (lower budget side, nothing too fancy)
My current PC specs: CPU i5 2400 3.4 ghz (4 cores/4 threads)
10gb Ddr3 ram 1600mhz
500 watt EVGA Powersupply
EVGA GTX 1060 SC 3GB
500Gb hdd
(pic of current one-->) https://drive.google.com/file/d/1JbZ9Rv-xP8eHtsC1jRgE8DPRQGmyTTJI/view?usp=sharing
This is the motherboard with cpu I got from someone https://drive.google.com/file/d/1w8_IGlnP9d7ZdrpY7oENssODOM3ft7Wz/view?usp=sharing (they tested it before sending, still works, however they mention the fan is on backwards so I plan on fixing that)
I know I need to install windows (through usb method?)
I also got Samsung 870 evo sata ssd 500gb which I believe can be used in place of my hdd right? Help is appreciated Thank you!
500Gb hdd
