First pc build/first post!!
blaze00111
4
Approximate Purchase Date: e.g.: this month
Budget Range: 600-700 dollars.
System Usage:gaming
Are you buying a monitor: no(already hav one)
Do you need to buy OS: No
Preferred Website(s) for Parts: anywere.
Parts Preferences: AMD
Overclocking: maybe(most likley yes)
SLI or Crossfire: No
Your Monitor Resolution: 1080p (1920 × 1080)
DO NOT NEED:keyboard,mouse,monitor, or operating system.
Parts that i have put together already on newegg:
CPU: AMD FX-6300 Vishera 3.5GHz (4.1GHz Turbo) Socket AM3+ 95W Six-Core Desktop Processor.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113286
CASE:Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
HDD:Western Digital WD Blue WD5000AAKX 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136769
optical drive:LG 24X DVD Burner.
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136259
RAM:Mushkin 997008 DDR3 UDIMM (2x4GB) 8GB PC3-14900 1866MHZ 9-10-9-27 Redline Ridgeback 1.5V
http://www.amazon.com/Mushkin-997008-PC3-14900-9-10-9-27-Ridgeback/dp/B0052WLU4Q/ref=sr_1_2?ie=UTF8&qid=1356671960&sr=8-2&keywords=Mushkin+Redline+8GB+%282+x+4GB%29+DDR3-1866+Memory
MObO:ASUS M5A78L-M LX PLUS AM3+ AMD 760G Micro ATX AMD Motherboard
http://www.amazon.com/M5A78L-M-LX-PLUS-Micro-Motherboard/dp/B005WUUFBW/ref=sr_1_3?s=electronics&ie=UTF8&qid=1356672151&sr=1-3&keywords=am3%2B+motherboard
PSU:NZXT Hale82N 650W 80 Plus Bronze Active 240-Pin Non-modular Power Supply, Black np-1bn-0650a-us
http://www.amazon.com/Hale82N-Bronze-240-Pin-Non-modular-np-1bn-0650a-us/dp/B008RK9VFU/ref=sr_1_4?s=electronics&ie=UTF8&qid=1356672224&sr=1-4&keywords=NZXT+HALE82+650W+80+PLUS+Bronze+Certified+ATX12V+%2F+EPS12V+Power+Supply
and i would like to know what GPU you guys would suggest to me with this setup and i would like to know if there are any better/cheaper parts that i can use.
thanks.
while i do agree with you. the difference in parts between $500-1000 is pretty big. i guess it really just comes down to a ssd and the video card. does the video card also have to be amd?
edit: never mind he just posted the budget.
no,the gpu can b nvidia or amd as long as it fits in budget and i dont really want a ssd.
Just one question could you build anything better for the same budget using any parts you want?
Most people would say switch to intel. The new Piledriver/Vishera/Trinity line is a good improvement over the last (failed) model, and makes them competetive in certain areas, like mobile apu gaming and budget encoding, but intel still holds the lead on desktop gaming and top-end consumer encoding.
I made you a build i'm sure you'll be proud of
CPU: AMD FX-8320 3.5GHz 8-Core Processor ($149.19 @ Amazon)
CPU Cooler: Cooler Master Hyper 612 PWM 82.9 CFM Sleeve Bearing CPU Cooler ($39.99 @ Amazon)
Motherboard: Gigabyte GA-970A-UD3 ATX AM3+ Motherboard ($102.37 @ Newegg)
Memory: Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory ($35.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($69.99 @ NCIX US)
Video Card: EVGA GeForce GTX 660 Ti 2GB Video Card ($229.99 @ Newegg)
Case: BitFenix Merc Alpha (Black) ATX Mid Tower Case ($29.99 @ NCIX US)
Optical Drive: Sony AD-7280S-0B DVD/CD Writer ($18.99 @ Newegg)
Total: $696.50
(Generated by PCPartPicker 2012-12-28 04:43 EST-0500)
It's a real beast and there's pretty much nothing left to improve.
