First PC Build
Going to start my first PC build*
Can someone please let me know if the parts I have picked will be compatible with each other.
Help much appreciated*
CPU - I7-3970X*
GPU-*Asus GeForce GTX 690 4GB GDDR5 6008 MHz
PSU- Seasonic X Series 1200W
SSD – Intel 520 120GB Sata3*
MOBO- Asus Rampage IV Extreme*
CASE – Cosmos II*
RAM – Mushkin Readline Ridgeback 4*4 = 16GB*
DVD- Asus BD Drive – BC-12B1ST*
Sound Card – ROG Xonar Phoebus*
Water Cool Spec*
CPU Block – EK Supremacy – Acetal + Nickel*
GPU Block –*EK-FC690 GTX - Acetal + Nickel
Pump – Laing D5 Vario 12V Pump Motor*
Pump Top – EK-D5 X Top CSQ-Acetal*
Radiator – EK-Cool Stream RAD XT (480)*
Reservoir – EK – RES 3 250*
Fans 120mm – Scythe Gentle Typhoon AP-15 1850rpm Fans *4*
Tube – Primochill Pro LRT Black 3m*
Fittings *10 EK – PSC 10mm – G1/4 Black*
CPU - I7-3970X*
CASE – Cosmos II*
Water Cool Spec*
