First pc build help (portable - MicroATX size) (budget ~£1000)
Sep 5, 2018
4
I've done some basic research but I am still confused about parts that are compulsory and parts that are extra. I have looked for ideas and builds online for a good portable pc build, but there's a lot of information and I'm getting overwhelmed. I study abroad so I travel on the plane quite a few times a year, so I would like the pc to fit in my luggage but still not take up too much space.
System Usage (Most to least Important): Gaming (90%), surfing the internet(8%), watching movies(2%)
I will need a monitor and a lisence key for windows 10.
I'm new to this so I have no preferred website for parts. I also won't be able to get parts from stores, only online.
I do not want to take a lot of risks so overclocking and SLI/crossfire is a no. (unless you really recommend it)
I want a graphics card that will be able to run games like Warframe/tf2/Skyrim/Occasonal AAA game at 60fps on medium graphics, so a card that will do the job but not super expensive.
Thanks!
Z370 is pointless, as the 8400 cannot overclock. PSU is decent, but you can still get a quality one, for less.
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor (£161.96 @ PC World Business)
Motherboard: ASRock - B360M Pro4 Micro ATX LGA1151 Motherboard (£78.02 @ CCL Computers)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory (£133.51 @ Amazon UK)
Storage: Crucial - MX500 500GB 2.5" Solid State Drive (£77.99 @ Aria PC)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (£34.74 @ Aria PC)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB SC...
tejayd
545
Even a mini itx PC, monitor and keyboard with the necessary padding to keep it safe is going to be difficult/expensive to travel around with.
For a pc you may be able to squeeze an i5 8400, 16gb ram, 240gb ssd, gtx 1060 or AMD equivalents. Leaving some $ for a monitor.
Or a laptop with basically the same specs. (Obviously all parts are not going to be as fast as the pc) Maybe an i7 8750 instead. I'm from the US. But know a few of them around 1200 usd. So assuming it's close.
logainofhades
Your case selection is ATX, so transport will be difficult. You must have mail in rebates turned on, as that build is over $1.1k up front. This mini-itx would be much easier to transport.
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor (£134.39 @ Aria PC)
Motherboard: ASRock - AB350 Gaming-ITX/ac Mini ITX AM4 Motherboard (£104.05 @ More Computers)
Memory: Patriot - Viper 4 16GB (2 x 8GB) DDR4-3000 Memory (£134.02 @ Ebuyer)
Storage: Crucial - MX500 500GB M.2-2280 Solid State Drive (£78.00 @ Amazon UK)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive (£52.98 @ PC World Business)
Video Card: Zotac - GeForce GTX 1060 6GB 6GB AMP! Edition Video Card (£240.00 @ Novatech)
Case: Silverstone - RVZ01B Mini ITX Desktop Case (£86.99 @ Overclockers.co.uk)
Power Supply: Silverstone - 500W 80+ Gold Certified Fully-Modular SFX Power Supply (£80.99 @ Overclockers.co.uk)
Monitor: Asus - VS247HR 23.6" 1920x1080 60Hz Monitor (£98.39 @ Aria PC)
Total: £1009.81
Generated by PCPartPicker 2018-09-06 14:28 BST+0100
Sep 5, 2018
4
Thanks for pointing that out :) Wouldn't the CPU bottleneck the GPU? THanks
tejayd
545
The 1600 is kinda old but should still be fine. I originally had a build made I wanted to post and it was almost the same as his. I wasnt sure on the monitor. But his choice looks good. If you wanted to go intel you might want to look at something like this. I do think the 8400 with this mobo is a better choice. https://uk.pcpartpicker.com/list/Kvx2jy
CPU
PC World Business
Motherboard
Gigabyte - B360N AORUS GAMING WIFI Mini ITX LGA1151 Motherboard
AWD-IT
Memory
Ebuyer
Storage
Amazon UK
Aria PC
Video Card
Novatech
Case
Silverstone - RVZ02B HTPC Case
Scan.co.uk
Power Supply
Overclockers.co.uk
Monitor
Aria PC
* Some physical dimension restrictions cannot (yet) be automatically checked, such as cpu cooler / RAM clearance with modules using tall heat spreaders.
PRICE BREAKDOWN
Base Total: £991.07
Shipping: £11.50
Total: £1002.57
logainofhades
Video Card: EVGA - GeForce GTX 1060 6GB 6GB SC GAMING Video Card (£264.88 @ Amazon UK)
Case: NZXT - H400i MicroATX Mini Tower Case (£99.95 @ Overclockers.co.uk)
Power Supply: Corsair - TXM Gold 550W 80+ Gold Certified Semi-Modular ATX Power Supply (£67.99 @ Amazon UK)
Wireless Network Adapter: Asus - PCE-AC51 PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter (£27.95 @ Amazon UK)
Total: £946.99
Generated by PCPartPicker 2018-09-07 22:29 BST+0100
4
Thanks ^^
