I'm building my first machine and I need to reduce the price. Any advice on where I should cut down? Here is my part list: http://au.pcpartpicker.com/p/zPTkrH.
I want to be able to play Skyrim maxed out with an ENB and newer games such as The Witcher and Fallout 4 with acceptable fps on High. Basically a little future proofed. I'm not sure if I should keep the I7 or downgrade to an I5 and save some money. Would it be better to wait for gen 5? Is the GPU overkill? As for OS and large storage I can get those easily elsewhere. I might go to a 60GB SSD if I have to. My ideal budget for the build is $1500 AUD (about $1200 USD). I might set a budget of $1000 AUD for a build without a gpu and save for a high end card separately, would that be better? Is a 144Hz monitor worth the massive cost? The budget includes CPU, RAM, SSD, CPU fan, case, PSU, GPU, disk drive, and 144Hz monitor.
Thanks.
Thanks.
