So i just built a computer and i'm just seeing if it will all run and if it's a reliable build i will link all the parts i found thanks in advance.
Intel Core i5-3570K Quad-Core Processor 3.4 GHz 4 Core LGA 1155
Gigabyte Intel Z77 LGA 1155 AMD CrossFireX/NVIDIA SLI W/HDMI, DVI Dual UEFI BIOS ATX Motherboard GA-Z77X-D3H
Corsair Vengeance 8 GB ( 2 x 4 GB ) DDR3 1600 MHz (PC3 12800) 240-Pin DDR3 Memory Kit for Core i3, i5, i7 and Platforms SDRAM
Gigabyte AMD Radeon HD 7850 2 GB GDDR5 DVI-I/HDMI/2x mini-Displayport PCI-Express 3.0 Graphic Card
WD Blue 1 TB Desktop Hard Drive: 3.5 Inch, 7200 RPM, SATA 6 Gb/s, 64 MB Cache - WD10EZEX
Cooler Master Extreme Power Plus - 600W Power Supply
Windows 7 Home Premium SP1 64bit
Rosewill Gaming ATX Mid Tower Computer Case CHALLENGER
I was wondering if that would all sync well and if there was any parts that could be cheaper but be better if they are not better then don't worry but i would like to say thanks very much in advance.
