Hello i am 14 and saving up to build a PC. My current build is approximately $1,311, it is pretty expensive but i want a good gaming pc that can run most new games such PUBG and Overwatch at 60fps or higher. I had a friend go on pc case gear with me and pick out the parts. Ill list them down below, can you tell me if i can reduce the price in some areas while still getting good performance.
Part List:
CPU: Intel Core i5 7500
GPU: MSI GeForce GTX 1060 Gaming X 3GB
Motherboard: Gigabyte B250M-D3H
RAM: Corsair Vengeance LPX CMK8GX4M2A2133C13 8GB (2x4GB) DDR4
PSU: Be Quiet! System Power 8 500W Power Supply
HDD: Toshiba DT01ACA100 1TB 7200RPM
SSD: Kingston SSDNow A400 120GB
Case: Deepcool tesseract Mid tower
CPU Cooler: Thermaltake Riing Silent 12 Pro
Fans: Cooler Master SickleFlow X 120mm Blue LED Fan
Just give me suggestions on what i should change or if it is good. Thanks.
Part List:
