First PC build - No signal on display
LuxJosh
I just finished building my first PC and wanted to install the OS.
As I turned it on, the fans started spinning, LED's on the motherboard light up, but no signal on the display.
Even the LED's on my keyboard light up after a while and the Caps Lock light toggles when pressing the corresponding key.
Still I don't get any signal on my display.
I already tried the following:
1. Reset the CMOS
2. Tried changing memory slots/booting with one memory card
3. Made sure all cables a plugged in correctly
4. Unplugged HDD and SSD
5. Tried different monitor and different output (HDMI / VGA)
I can't seem to find the problem, does anyone of the Pro's here know what the problem could be?
Specs:
Motherboard:
- ASUS Prime B350-Plus
CPU:
- Ryzen 5 1600
RAM:
- Corsair Vengeance DDR4 2x8GB
PSU:
- EVGA 650GQ Gold
Do you have a GPU? Ryzen does not have a built in iGPU like Intel does. That's why it is a bit cheaper. You can get a cheap RX 460 or GeForce 1030 if you are not a gamer.
