F fattyoren Apr 12, 2020 3 0 10 Apr 24, 2020 #1 ComponentSelectionCPUAMD Ryzen 5 3600 3.6 GHz 6-Core ProcessorMotherboardGigabyte B450M DS3H Micro ATX AM4 MotherboardMemoryKingston HyperX Predator RGB 16 GB (2 x 8 GB) DDR4-3200 MemoryStorageSamsung 860 QVO 1 TB 2.5" Solid State DriveVideo CardSapphire Radeon RX 5700 XT 8 GB NITRO+ Video CardCaseCorsair SPEC-02 ATX Mid Tower CasePower SupplyCorsair CXM 650 W 80+ Bronze Certified Semi-modular ATX Power Supply
Solution siaan312 Apr 24, 2020 if youre hacky, get a non xt 5700 and flash its bios. otherwise that is a pretty good value mid range build.
siaan312 Dignified Jun 15, 2017 2,314 463 15,790 Apr 24, 2020 Solution #2 if youre hacky, get a non xt 5700 and flash its bios. otherwise that is a pretty good value mid range build. Upvote 0 Downvote Solution
