First PC Build Parts List...Feedback Please
Mar 11, 2018
13
Good evening all. I am looking to finally build my first PC but I have some questions. I'm designing this machine not to play all the highest end games. Rather I'm building something that can run a few virtual machines, do video editing and play one or two games (really just hoping to play Need For Speed Payback). I'm trying to be economical since I don't require the highest end parts, and this is the absolute top of my budget anyway. I just want to make sure all of the parts on my list are compatible with each other. That's my first question (will all these parts work with each other).
Processsor : https://www.amazon.com/dp/B009O7YUF6/ref=sxts_kp_lp_2?pf_rd_m=ATVPDKIKX0DER&pf_rd_p=8778bc68-27e7-403f-8460-de48b6e788fb&pd_rd_wg=wVyrB&pf_rd_r=90ACAXWNBSM17MHX3JSK&pf_rd_s=desktop-sx-top-slot&pf_rd_t=301&pd_rd_i=B009O7YUF6&pd_rd_w=KfLPI&pf_rd_i=processor&pd_rd_r=18dd3997-04eb-4bed-b384-bb1d6d2eb58b&ie=UTF8&qid=1542246492&sr=2&th=1
Motherboard : https://www.amazon.com/Gigabyte-4xDDR3-Realtek-4xUSB3-1-Motherboard/dp/B079GRXBDJ/ref=pd_bxgy_147_2?_encoding=UTF8&pd_rd_i=B079GRXBDJ&pd_rd_r=ad5890b5-e88f-11e8-964f-c758f514dd56&pd_rd_w=OvnlW&pd_rd_wg=FlZBW&pf_rd_i=desktop-dp-sims&pf_rd_m=ATVPDKIKX0DER&pf_rd_p=6725dbd6-9917-451d-beba-16af7874e407&pf_rd_r=TSF7E8SF5CRADMTGAV63&pf_rd_s=desktop-dp-sims&pf_rd_t=40701&psc=1&refRID=TSF7E8SF5CRADMTGAV63
RAM : https://www.amazon.com/Patriot-Viper-1600MHz-Channel-PV38G160C9K/dp/B008LTJJM2/ref=pd_bxgy_147_3?_encoding=UTF8&pd_rd_i=B008LTJJM2&pd_rd_r=beb461b6-e88f-11e8-acef-0dacba850be4&pd_rd_w=n0ev8&pd_rd_wg=NOuCH&pf_rd_i=desktop-dp-sims&pf_rd_m=ATVPDKIKX0DER&pf_rd_p=6725dbd6-9917-451d-beba-16af7874e407&pf_rd_r=1NVV6SH9J7C7E2NYR49B&pf_rd_s=desktop-dp-sims&pf_rd_t=40701&psc=1&refRID=1NVV6SH9J7C7E2NYR49B
GPU : https://www.amazon.com/MSI-GeForce-GTX-1060-6GT/dp/B01LZYPEHK/ref=sr_1_4?s=pc&ie=UTF8&qid=1542251581&sr=1-4&keywords=gtx+1060+6gb&dpID=41VEZRWJyTL&preST=_SX300_QL70_&dpSrc=srch
PSU : https://www.amazon.com/EVGA-BRONZE-Warranty-Tester-100-B1-0600-KR/dp/B00EON40CS/ref=sr_1_5?s=pc&ie=UTF8&qid=1542252871&sr=1-5&keywords=power+supply&dpID=51Zd5PuGxSL&preST=_SY300_QL70_&dpSrc=srch
Storage : https://www.amazon.com/dp/B073SB2MXW/ref=twister_B07BXDZ5FR?_encoding=UTF8&psc=1
Also getting :
https://www.amazon.com/LG-Electronics-Portable-External-GP65NB60/dp/B00ODDE33U/ref=sr_1_4?s=pc&ie=UTF8&qid=1542253174&sr=1-4&keywords=dvd+drive
and probably this : https://www.amazon.com/Cooler-Master-RR-212E-20PK-R2-Direct-Contact/dp/B005O65JXI/ref=bdl_pop_ttl_B005O65JXI
although I wondered if I needed it, or could I get away with just the stock fan that comes with the processor?
So that's my list. Is there anything else I need (extra fans, etc) and are there any other misc things I should make sure and get to actually build the thing? I'm a 100% novice when it comes to building a PC so anything else I should know? For the purposes I described, what do you folks think of the build?
Thanks for your time and info
ArchitSahu
Admirable
DO NOT waste your money on the FX series. It was garbage when it came out and even more so now. Do you need a Case?
I am assuming your budget is $600:
Ryzen -
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor ($159.99 @ Amazon)
Motherboard: ASRock - B450M PRO4 Micro ATX AM4 Motherboard ($54.99 @ Newegg)
Memory: Team - Vulcan 8 GB (2 x 4 GB) DDR4-3000 Memory ($69.99 @ Newegg)
Storage: Team - L5 LITE 240 GB 2.5" Solid State Drive ($29.99 @ Newegg Business)
Storage: Western Digital - RE4 1 TB 3.5" 7200RPM Internal Hard Drive ($39.83 @ Amazon)
Video Card: Gigabyte - GeForce GTX 1060 6GB 6 GB D5 6G Video Card ($229.99 @ Newegg)
Case: Rosewill - FBM-X1 MicroATX Mini Tower Case ($17.99 @ Amazon)
Power Supply: Corsair - CX (2017) 550 W 80+ Bronze Certified ATX Power Supply ($29.99 @ Newegg)
Total: $632.76
Generated by PCPartPicker 2018-11-15 01:41 EST-0500
Has a case as well.
Mar 11, 2018
13
Seems like a good build. Would it worth me exchanging that GPU for something like this (https://www.amazon.com/MSI-RX-580-8G-OC/dp/B06XZQMMHJ/ref=bdl_pop_ttl_B06XZQMMHJ)? Amazon sells them together for not too much more expensive.
Also, is there anything else I will need? Any kind of other parts I'll need, like maybe cables, extra fans etc?
ArchitSahu
Admirable
Up to you. If your monitor has free sync, then the 580 will be a better fit. Both are very nearly comparable in performance.
You might need an extra fan or two, just make sure the motherboard has enough headers for these fans and the ones that might come with the case. You should be okay without.
Similar threads
