First PC build- thoughts, problems, or changes?
amd0808
Commendable
Dec 27, 2016
This is going to be my first PC i'm building. If there are any problems please tell me. Any suggestions on changing things also tell me.
graphics: MSI GeForce GTX 1060 6GB GAMING X Video Card
storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
motherboard: Asus B150M PRO GAMING Micro ATX LGA1151 Motherboard
memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor
CPU cooler: zalman CNPS10X Performa CPU Cooler
case: Corsair Obsidian Series 450D Black Brushed Aluminum and Steel ATX Mid Tower Case
power supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply
case fan: Corsair Air Series AF140 Quiet Edition 67.8 CFM 140mm Fan
I don't know much about computers or building them.
i don't plan to overclock i've just heard those are good options for a computer
Almost only for gaming. I don't know much about computers so any info you have will be helpful!
- I5-6600k will be unnecessary since you won't overclock.
- The DDR4-3000 memory will run at DDR4-2133Mhz limit (Only Z170 can do higher).
- EVGA NEX B1/G1 650 watts are lower quality power supplies. There are better options for the price.
- Might be missing the load speeds of an SSD, seeing it excluded.
From which country are you buying?
Sorry so late, I'll be buying from the US. If you want could you tell me what i should do for the parts instead of what i have now?
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor ($189.69 @ SuperBiiz)
Motherboard: ASRock B250M Pro4 Micro ATX LGA1151 Motherboard ($82.98 @ Newegg)
Memory: G.Skill Ripjaws 4 Series 16GB (2 x 8GB) DDR4-3000 Memory ($84.97 @ Jet)
Storage: Kingston SSDNow UV400 240GB 2.5" Solid State Drive ($67.88 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.78 @ OutletPC)
Case: Fractal Design Define Mini C with Window MicroATX Mid Tower Case ($79.99 @ NCIX US)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply ($49.99 @ B&H)
Total: $605.28
Generated by PCPartPicker 2017-01-07 05:44 EST-0500
Motherboard: ASRock Z170 Pro4S ATX LGA1151 Motherboard ($89.99 @ Newegg)
Case: Deepcool DUKASE V2 ATX Mid Tower Case ($52.99 @ SuperBiiz)
Total: $585.29
Generated by PCPartPicker 2017-01-07 05:47 EST-0500
Thank you so much ill look into those! since there is an SSD and hard drive would i use the SSD as my system drive, and the hard drive for data, or use only one of them.
Ok thanks so much for the help!
