First PC Build
UltimateGio
So I'm think about building this PC, its my first one, never have build one before. I don't know to much about PC, I only know the basic things.
I was thinking about this one: http://pcpartpicker.com/p/2UodI
I'm mainly going to be using this computer for rendering and editing videos. I might play a few games like Arma 2, maybe COD. There's a few things I'm not fully convinced in getting, those are the motherboard, the case, and the fans.
Any suggestions on what I should improve in this build?
Thanks for the help!
Here you go:
CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor ($304.99 @ NCIX US)
CPU Cooler:...
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130692
I'd recommend the z87-gd65 motherboard if you plan to overclock
Otherwise, I think if you are using this computer to mostly video edit, you will want a better graphics card. At least a 770 for that amount.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125463
Remove the thermal compound, you get some with your motherboard, and consider dropping some of your case fans if this goes over your budget. If that still doesn't cut it, use an i5-4670k instead of the i7-4770k
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116899
Here you go:
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.98 @ OutletPC)
Motherboard: Gigabyte GA-Z87X-UD4H ATX LGA1150 Motherboard ($159.99 @ Microcenter)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory ($84.99 @ Newegg)
Storage: Samsung 840 Pro Series 128GB 2.5" Solid State Disk ($114.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($59.98 @ OutletPC)
Video Card: MSI GeForce GTX 770 2GB Video Card ($334.98 @ SuperBiiz)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case ($89.99 @ Microcenter)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply ($85.99 @ Amazon)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($19.98 @ OutletPC)
Total: $1285.86
(Generated by PCPartPicker 2014-02-16 17:28 EST-0500)
