First PC Build
cooldude8530
158
I have just finished building my first PC and everything works and is installed correctly but mybpsu power cord is VERY lose and every time I plug it in I have to hold it in. I got an Evga psu. I was wondering is there a way to fix this or is it their problem?
I would try using another cable if you have one but yeah that doesn't sound right. If it won't stay plugged in and literally falls out it's a manufacturer defect and you should complain to the manufacturer.
I do mean the female side that goes into the psu
