First PC Build!!
Sudhanwa
26
Hello Friends,
What are your thoughts on following list of parts that I have selected for my first PC build.
I want to make sure that all parts are compatible with each other.
Intel Core i7 6700k
Asus Z170 Deluxe
Zotac GTX1070 AMP! Extreme Edition
Corsair Vengeance LPX 16GB 2x8GB DDR4 DRAM 3200MHz PC4-25600 C16 Memory Kit - Black
Samsung 850 evo 256GB
Seagate Desktop 2 TB SSHD
Corsair CP-9020098-WW VS Series VS650 650 Watt Power Supply Unit (Black)
Corsair CC-9011051-WW Carbide Series SPEC-02 Steel Red LED Mid-Tower Gaming Case (Black)
Cooler Master Hyper 212X
What about this PSU
Corsair RMx SeriesTM RM650x - 650 Watt 80 PLUS® Gold Certified Fully Modular PSU - (CP-9020091-EU)
Is cabinet and cooler choice correct ?
Else suggest
Can u give link for CPU cooler ?I am confused
Really you want Tier 1 http://www.tomshardware.co.uk/forum/id-2547993/psu-tier-list.html
Ok,I have gone through list
But what about wattage ?
It would be nice,if u can pinpoint me to specific PSU (Preferably amazon link)
Its good but from what I read there are better for that price?
Like which one?
The RMx is the king of Gold supplies, cheaper than the Super Flower Leadex II, better than the Seasonics & the Super Flower/Seasonic OEMs
Comes with semi-passive cooling, highgrade components, long warranty.
Would a Seasonic S12II power this build? Probably. But why going cheap on the PSU when building a high end rig.
If a XFX XTR or a EVGA Supernova G2/G3/GS are cheaper, of course they'll viable options.
The AMP Extreme is a hungry card. 550W+ are required.
Thanks for ur assistance.(and the other guy too)
Ok,I shall go ahead with this PSU : Corsair RMx SeriesTM RM650x - 650 Watt 80 PLUS® Gold Certified Fully Modular PSU - (CP-9020091-EU)
because ,somewhere I read that 650W is enough for single GPU
But do u have any alternatives for cooler ?
cuz it is not available in my region's amazon website
or tell me cabinet that goes with my existing selection of components
The case and cooler you picked will work.
Very little difference in I and 2 and their a ton of people using tier 3 without issues.
I don't really believe in a tier list their should really only be 3 levels good, acceptable, and bad.
