First PC Build
Ace Carbon
Hello to the community and anyone who reads this im building my first pc soon and i have a general direction in which way to pick parts i just needed feedback on which case to get and which type of monitor also any other feedback would be great
CPU:Intel Core i7-7700K 4.2GHz Quad-Core Processor
CPU Cooler: EK-KIT P360 liquid cooling system///from EKWB
Thermal Compound:Arctic Silver 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: MSI Z270 GAMING M5 ATX LGA1151 Motherboard
Ram: Kingston FURY 32GB (2 x 16GB) DDR4-2133 Memory
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive//Seagate Constellation ES.3 4TB 3.5" 7200RPM Internal Hard Drive
Graphic Card:Gigabyte GeForce GTX 1080 Ti 11GB Founders Edition Video Card
Case:Cant Decide
Power supply:EVGA SuperNOVA P2 750W 80+ Platinum Certified Fully-Modular ATX Power Supply
Unless you do heavy video editing 32GB Ram aren't necessary.
A 650W PSU is more than you'll need
Lose the thermal compound, the one included is sufficient
As for cases​, it depends on what you're looking for.
A stylish all glass case? Look at the anidees crystal or the Corsair crystal
Maximum airflow? Phanteks Enthoo series
Silent? Thermaltake F51 or BeQuiet Silent Base or NZXT Phantom or Fracal Design Define/R5
- a bit of everything: NZXT H series, Phanteks P400S
Important question: WHAT are you going to use your PC for?
* IF * Just Gaming and maybe lightly threaded workloads, stick with the Intel build
* IF * Gaming + streaming and/or heavily threaded workloads, go with a Ryzen 1700 build
Ryzen gives 90-95% if 7700k performance in most games, with some improvement to come as devs have time to work with it and optimize. But it gives 1.5-2x 7700k performance in heavily threaded workloads like video capture/edit/encoding, depending on the apps being used.
So this is a time where your use case for your PC DOES matter when trying to determine the best build options.
Why? Ryzen isn't perfect for the time being, I would wait until AMD gets all the bugs worked out of it before I'd say it's a purchase. I would stick with Intel for the time being. It's definitely a huge step in the right direction over FX but it's not entirely perfect.
