Chuck_223 :
mbilal2 :
Are you trying to keep the theme blue, red, rgb?
well im not really goin for colors and flashyness, i just picked the case because it had good ratings and is cheap. also just realized i probably wont be able to use the ram from my old pc cause its probably ddr3 too. would something like
https://m.newegg.com/products/N82E16820233852 work? if so that brings the current price of build up to 809 (with motherboard and cooler removed)
That is a great RAM. I put it in for you. Here is your new PC build:
PCPartPicker]https://pcpartpicker.com/list/Rgn2Cy]PCPartPicker part list: HERE[/url]
Price breakdown by merchant: HERE
CPU: AMD - Ryzen 7 1700 3.0GHz 8-Core Processor ($294.49 @ SuperBiiz)
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste ($5.88 @ OutletPC)
Motherboard: Gigabyte - GA-AX370-Gaming ATX AM4 Motherboard ($101.98 @ Newegg)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3200 Memory ($136.88 @ OutletPC)
Storage: Western Digital - Blue 250GB M.2-2280 Solid State Drive ($89.99 @ B&H)
Storage: Hitachi - Ultrastar 7K4000 3TB 3.5" 7200RPM Internal Hard Drive ($65.92 @ Amazon)
Case: NZXT - S340 (Black/Red) ATX Mid Tower Case ($64.99 @ Newegg)
Power Supply: EVGA - SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($74.88 @ OutletPC)
Total: $835.01
The Ryzen 1700 comes with a stock rgb cooler. Notr the Ryzen has twice as many cores and threads than the 7700k. However if you want to go for intel,
PCPartPicker part list HERE.
CPU: Intel - Core i7-7700K 4.2GHz Quad-Core Processor ($309.99 @ Amazon)
CPU Cooler: CRYORIG - H5 Universal 65.0 CFM CPU Cooler ($46.99 @ Newegg Marketplace)
Motherboard: Gigabyte - GA-Z270-HD3 ATX LGA1151 Motherboard ($114.99 @ Amazon)
Total: $910.51
You can mess around and change stuff in there by clicking "edit part list".
These two rigs will set you for a good 5ish years. You will however need to upgrade your graphics card. It will be the only thing holding back your beast of a computer!
Let me know if u need more help. The cooler with the second build is one of the best air coolers for the price. You can pay about 50$ more and get a decent water cooler.
