daneshL_ :
constantine_99 :
@OP
a GTX 1050ti will perform better than that GPU (driver compability, less wattage usage, newer technology and so on)
i would also suggest u get a 1x8 instead so later on u can add another 1x8
Is 16gb really neseccary though? Read a lot about it, but still dont know If 16gb ram is an overkill or not.
depending on your games, it might / might not be overkill
while 8 GB is enough, some games can utilize more in order to smoothen your experience even more
if u willing to step up just a few more $, u can get the B350M Mortar instead, which had 4 RAM slot, so u can get the 2x4 now, and add another 2x4 later on
also, i've done some readings and can't seems to find EVGA BQ in the PSU tier list, better get some other high tier PSU instead, Seasonic S12II / M12II or perhaps EVGA G2/G3, maybe the Corsair CXM or RM can be another alternative for u
http://www.tomshardware.com/forum/id-2547993/psu-tier-list.html
forgot to tell u this too: it's not worth it to buy 1300X, the only difference X version CPU gives is an auto-OC feature, with some learning into OCing, u can get the 1200 to reach the 1300X performance at ease and save a few more $, but if u don't want the hassle of having to set everything manually, the X version's feature will do that for you, they will OC it as high as the situation allows.
while the GPU 770 offers the same performance as 960 and 1050ti, i rather get a new gen GPU instead, as the driver compability, and less wattage required, also if u bought it used, it will have no warranty and it might on the verge of dying too, which is another point to be considered.
