[SOLVED] First pc build
Aug 13, 2021
52
Hi, I'm need a good pc for minecraft and minecraft only. So hard to get a answer on YouTube because everyone says somthing difrent. I mostly want to get a prebuild for 900 to 1k but everyone says somthing difrent and I dont wana make a bad move. If anyone could point me on the right direction it would be greatly appreciated. 🙂
4 core CPU with only 3.9GHz Boost Clock,
7 year old very low end GPU,
only 8GB of unspecified RAM.
could be worth ~$700 with a very nice case, reliable power supply, and nice motherboard.
none of these are mentioned.
but it will still not get good performance with any modern games if this is the intended use.
Are you planning to use shaders? Maybe you want to try these:
PCPartPicker Part List
Type|Item|Price
CPU | AMD Ryzen 5 5600G 3.9 GHz 6-Core Processor | $329.99 @ Amazon Canada
CPU Cooler | Deepcool GAMMAXX 400S 50.8 CFM CPU Cooler | $24.99 @ Amazon Canada
Thermal Compound | Gelid Solutions GC-Extreme 3.5 g Thermal Paste | $11.99 @ Amazon Canada
Motherboard | MSI MAG B550M MORTAR WIFI Micro ATX AM4 Motherboard | $206.50 @ Vuugo
Memory | G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory | $109.99 @ Memory Express
Storage | Team MP33 1 TB M.2-2280 NVME Solid State Drive | $110.99 @ Canada Computers
Case | Phanteks Eclipse P400A Digital ATX Mid Tower Case | $98.98 @ Amazon Canada
Power Supply | Corsair RMx (2018) 550 W 80+ Gold Certified Fully Modular ATX Power Supply | $78.98 @ Amazon Canada
| Prices include shipping, taxes, rebates, and discounts |
| Total | $972.41
| Generated by PCPartPicker 2021-08-22 16:02 EDT-0400 |
If you're buying everything on this list, make sure:
  1. Contact the seller to update the bios to the latest (its a must, for the processor support)
  2. When you're building the PC, make sure the ram is on slot 2 and 4. and go into bios before you install windows, select XMP Profile 1 in corner left, then Save and Exit (F10)
  3. 3.Don't use stock thermal paste from gammaxx 400s, instead use Gelid GC Extreme for thermal paste for Gammaxx 400S.
  4. 4.Install windows, then amd chipset driver, then amd radeon driver
  5. you're good to go on installing any games you want
I need a 2nd opinion on these specs for a pc I wana buy for 600 cad
500w power supply
CPU - i7 2600k up to 3.8 GHz, 4 cores 8 threads
Cooler - New Coolermaster Hyper 212 Black
GPU - EVGA GTX 970 4GB GDDR5
RAM - 16GB Kingston DDR3 @ 1600 MHz
Mobo - MSI P67A-G43
PSU - New 500W EVGA 80+
SSD - New 120GB Kingston
HDD - 500GB Toshiba @7200 rpm
Case - NZXT S340
Main game would be moded minecraft 1.8.9
I'm thinking about getting this pc for 880 cad, here are the specs:
AMD Ryzen 3 3100 3.6GHz,
GeForce GT 1030 2GB,
8GB DDR4, 240GB SSD, 2TB HDD
WiFi Ready
Windows 10 Home
Condition
New
Model
Rainbow2701
Storage Type
HDD + SSD
Operating System
Windows 10
RAM Size
16 GB
Custom Bundle
No
Brand
Onfite
Connectivity
DVI-D, WiFi, Bluetooth, HDMI, USB 2.0, USB 3.0
Manufacturer Warranty
1 year
Series
Onfite Rainbow
Form Factor
Micro Tower
Processor Speed
3.40 GHz (3.8 GHz w/ Intel Turbo)
Operating System Edition
Professional
Features
Tempered Glass Side Panel, Rainbow LED Fans, Wi-Fi Adapter, Bluetooth Adapter, Mesh Front Panel, Dust Shield
Processor
Intel Core i7-2600
Hard Drive Capacity
1 TB
SSD Capacity
120 GB
MPN
Rainbow2701
GPU
AMD Radeon RX 560 4GB DDR5
UPC
Does not apply
this is more decent for the price:
Type|Item|Price
CPU | Intel Core i3-10100F 3.6 GHz Quad-Core Processor | $157.96 @ Amazon Canada
Motherboard | ASRock B560M Pro4 Micro ATX LGA1200 Motherboard | $102.50 @ Vuugo
Memory | G.Skill Ripjaws V Series 8 GB (2 x 4 GB) DDR4-3200 CL16 Memory | $59.99 @ Memory Express
Storage | Team MP33 256 GB M.2-2280 NVME Solid State Drive | $49.54 @ Vuugo
Storage | Western Digital Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive | $48.99 @ Canada Computers
Video Card | Asus GeForce GTX 1050 Ti 4 GB Phoenix Video Card | $308.08 @ Amazon Canada
Power Supply | be quiet! System Power U9 600 W 80+ Bronze Certified ATX Power Supply | $59.99 @ Amazon Canada
| Total (before mail-in rebates) | $916.03
| Mail-in rebates | -$30.00
| Total | $886.03
| Generated by PCPartPicker 2021-08-22 23:45 EDT-0400 |
Could do worse. However, not sure about the power supply they use. The other thing is they use an a320 motherboard. Which is ok I suppose, you just won’t probably be upgrading the cpu without replacing the board later, and you won’t be able to overclock, at least much. But on the other hand, for your first pc, you don’t need to bother with overclocking.
If you get it, I’d recommend to upgrade it to 16gb ram, and maybe replace the power supply eventually.
The other thing I’m not a fan of is the case they use. It looks nice, but even though they put 3 fans in the front of the case, The front of the case looks like there wouldn’t be a lot of fresh air being pulled in. The other thing, you’d probably want to upgrade to 16gb of ram.
it’s probably an ok pc but I might consider passing.
I dunno, looked at so many prebuilds and so much pcs.. this just seems like the best option right now. Everything these days has horrific parts to value. Such a tricky thing. I guess everything can't be perfect. If it preforms well I don't think I would need to upgrade it 2 much.
Yeah as I started looking you are right. I was editing when you replied. But if you get that system, I’d try to upgrade to 16gb of ram and later on, certainly before upgrading the video card, I’d recommend to replace the power supply. Also keep an eye on temperatures on the components. May not be a bad idea to see if you can add more fans. Looking again though that does appear to have a mesh front. So that’s good. A lot of times those cases have a plastic or glass front that impedes air flow.
I suppose for the money go for it, but as I said, I’d recommend upgrading to 16gb. A dual channel kit would probably run 60-70 dollars, and later on replace the power supply, especially when you’d get ready to upgrade the video card.
Yea, il probability get it and if things go down hill il upgrade some components but well cross that bridge when we come to it.
