First Real Gaming Build Need Advice
kleptorazer
8
I am building my first real gaming build and purchasing everything in about a week. I want to stay on air cooling, and want to stay ridiculously high end. I would just like to know any suggestions, and or comments on my current build plan. My plan is as follows:
Case - COOLER MASTER HAF X RC-942-KKN1 - 189.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225
Mobo - ASUS Maximus IV Extreme-Z - 349.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131760
CPU - Intel Core i7-2600K Sandy Bridge - 314.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070
CPU Cooler - Noctua NH-D14 - 85.87
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608018
GPU - 2x MSI N580GTX Lightning Xtreme Edition GeForce GTX 580 - 599.00 Each
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127589
RAM - CORSAIR Vengeance 16GB Low Profile (To fit under CPU cooler) - 104.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233198
PSU - CORSAIR Professional Series Gold AX1200 - 279.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139014
HDD - 2x Western Digital VelociRaptor WD6000HLHX in Raid 0 - 249.99 each
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136555
There also other components such as my DVD drive, monitor, keyboard, and mouse ect.
Big things that i would like advice on are the two video cards, mobo, and HDD's.
Note - I have a 3rd video card i am going to use as a dedicated phys x card. This card is a GTX 460.
I would love to hear what sugestions you guys have, I will be here listening and commenting.
Thanks for your help.
-Josh
Are you seriously going to spend that much... :pt1cable:
I built my i7-2600k for under 1500.
I'm running a Gigabyte P67 a ud-4 Mobo
i7-2600k
Corsair h50 cooler w/ a second fan
2 Sata3 HD 1 sys, 1 data
HD6850 video (yes this is a weak point)
Antec 600 case
and 1833 RAM (don't remember which)
The system is stable @ 4.20 GHz
Do some more research, donate $500 to charity and you will still have an awesome system.
^ Why go overboard?
The 2500K performs 98% of the 2600K in gaming. Easily the 2500K can overclock past that little 2% differential.
The 2X580's are huge waste of money, especially since no game in the current day (especially not BF3) would require that even at 2560x1600.
http://www.guru3d.com/article/geforce-gtx-580-sli-review/6
Even CF 6870's (A third of the cost) perform quite close as shown at 1920x1200. Now that's pretty funny.
You wouldn't even need that PSU for SLI 580's Corsair PSU's are overpriced and pretty much a ripoff. This is overkill for any system but cheaper and a better deal than any of those Corsair ripoffs
http://www.newegg.com/Product/Product.aspx?Item=N82E16817814019
V-Raptor drives are ripoff, why don't you just get a single 240GB SSD and a 1TB F3 for main storage? You'd save money and still get way faster boots and more storage space as well.
ROG boards are also a huge waste of money. Are you trolling us or something? An Asrock Extreme4 Gen3 Z68 could easily perform to that boards level and still save you money as well as giving you the future proof of PCI-E 3.0 which the Maximus doesn't offer. Spending that much now, doesn't mean future proof. It is just a waste since 7000 series is coming soon and Kepler as well plus SB-E and BD as well.
what resolution will you be playing at and what is your budget?
I was going to suggest Crossfire 6970's but since your only gaming on a single monitor @ 1920x1080, maybe SLI 570's would be better? Or even just a single 580 with room to add another in the future? Thoughts anyone?
try a tri monitor setup.... three of these- http://www.amazon.com/gp/product/B005BZNDS0/ref=s9_simh_gw_p147_d0_g147_i3?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=07J0HRX6P4G5EVSTFB4Q&pf_rd_t=101&pf_rd_p=470938631&pf_rd_i=507846 x3=555$ these are 24" 2ms 60hz monitors. i dont know what monitor you have. is it 2ms? and what is the size?
i5 2500k- http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072 220$ there is no performance gap between the 2500k and 2600k in gaming situations
Asrock Z68 Extreme7 Gen3- http://www.newegg.com/Product/Product.aspx?Item=N82E16813157269&Tpk=asrock%20extreme7 280$ you can upgrade to sandy bridge
Plextor 256gb ssd- http://www.newegg.com/Product/Product.aspx?Item=N82E16820249011&Tpk=plextor%20256gb 380$ big fast and much more reliable than the sandforce ssd's
Samsung F3 1tb- http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185 60$
Gskill 8gb 1866mhz- http://www.newegg.com/Product/Product.aspx?Item=N82E16820231460 70$
Silverstone Raven RV03- http://www.amazon.com/Silverstone-Extended-90-Degree-Motherboard-RV03B-W/dp/B004X19B02/ref=sr_1_1?ie=UTF8&qid=1315234132&sr=8-1 140$ this case actually cools better than the Haf X with its fans on high (it is still quieter) and forces you to have cable management.
CPU Cooler- http://www.amazon.com/Corsair-Performance-Liquid-Cooler-CWCH80/dp/B0051U7HMI/ref=sr_ob_4?s=electronics&ie=UTF8&qid=1315234265&sr=1-4 100$ cools better than the noctua and it is also not so giant
quieter fans for the h80- http://www.amazon.com/Cooler-Master-120mm-Case-R4-C2R-20AC-GP/dp/B0026ZPFDE/ref=sr_1_3?s=electronics&ie=UTF8&qid=1315234418&sr=1-3 17$
Corsair AX1200- http://www.amazon.com/Corsair-Professional-1200-Watt-Certified-High-Performance/dp/B003PJ6QVU/ref=sr_1_1?s=electronics&ie=UTF8&qid=1315234468&sr=1-1 280$ the ax1200 is the best psu on the market and with that giant budget of yours i give it a nod
EVGA GTX 570 HD- http://www.amazon.com/EVGA-GeForce-DisplayPort-PCI-Express-Graphics/dp/B004L9LT24/ref=sr_1_3?s=electronics&ie=UTF8&qid=1315234989&sr=1-3 320$x3=960$ 2 580's are 900$ at the lowest so this is not a bad deal.
