First system build-$2500- will it work? will it fit?
quiescens
7
Approximate Purchase Date: September 2014
Budget Range: 2400-2600
System Usage from Most to Least Important: gaming, music production (edm), 2 screens (need 2 hdmi ports)
Parts Not Required: everything I need is on the parts list
Preferred Website(s) for Parts: pcpartpicker.com
Country: I live in the United States, if that's important
Parts Preferences: no preference
Overclocking: Maybe
SLI or Crossfire: Yes
Monitor Resolution: 1920x1080
Additional Comments: I have been doing research on the parts but I feel like I'm missing something. recommendations for parts is appreciated, if you can tell me why the part you're recommendin will work better for me that would be even more helpful
Part list:
http://pcpartpicker.com/p/3GYIs
I wrote out the whole explanation for the parts I've replaced, and when I posted it I noticed that it was the duplicate post and that my post was deleted.
Well that's just bad luck. I'm not typing it all out again, but if you want to know anything about a specific part just let me know and I'll tell you.
Here's the revised build.
CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor ($319.99 @ Amazon)
CPU Cooler: Noctua NH-D14 65.0 CFM CPU Cooler ($78.99 @ Newegg)
Thermal Compound: Arctic Silver 5 High-Density Polysynthetic Silver 3.5g Thermal Paste ($6.98 @ OutletPC)
Motherboard: Asus Z87-Plus ATX LGA1150 Motherboard ($154.99 @ NCIX US)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory ($79.99 @ Newegg)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Disk ($139.00 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($56.19 @ Amazon)
Video Card: PNY GeForce GTX 770 2GB Video Card (2-Way SLI) ($299.99 @ Amazon)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case ($119.99 @ NCIX US)
Power Supply: SeaSonic G-750 750W 80+ Gold Certified Semi-Modular ATX Power Supply ($94.99 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($19.98 @ OutletPC)
Operating System: Microsoft Windows 7 Professional SP1 (OEM) (64-bit) ($136.98 @ OutletPC)
Sound Card: Asus Xonar DX 24-bit 192 KHz Sound Card ($81.98 @ Best Buy)
Case Fan: Fractal Design FD-FAN-SSR2-140 66.0 CFM 140mm Fan ($10.99 @ Newegg)
Keyboard: Corsair Vengeance K70 Wired Gaming Keyboard ($107.99 @ Amazon)
Mouse: ROCCAT Kone XTD Wired Laser Mouse ($61.98 @ Newegg)
Headphones: Logitech G930 7.1 Channel Headset ($89.99 @ Amazon)
Total: $2180.95
(Generated by PCPartPicker 2014-05-09 18:35 EDT-0400)
CPU Cooler: be quiet! Dark Rock Pro 3 93.3 CFM Fluid Dynamic Bearing CPU Cooler ($79.99 @ NCIX US)
Motherboard: Gigabyte GA-Z87X-OC ATX LGA1150 Motherboard ($149.49 @ Newegg)
Memory: A-Data XPG V2 16GB (2 x 8GB) DDR3-1866 Memory ($149.99 @ Newegg)
Storage: Plextor M5S Series 256GB 2.5" Solid State Disk ($149.99 @ Micro Center)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($83.97 @ OutletPC)
Video Card: EVGA GeForce GTX 770 2GB Dual Superclocked ACX Video Card (2-Way SLI) ($339.99 @ NCIX US)
Case: Corsair 760T Black ATX Full Tower Case ($159.99 @ Micro Center)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer ($14.99 @ NCIX US)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) ($89.98 @ OutletPC)
Monitor: Asus VX228H 60Hz 21.5" Monitor ($144.99 @ Newegg)
Case Fan: be quiet! SilentWings 2 102.6 CFM 140mm Fan ($29.99 @ NCIX US)
Keyboard: Corsair Vengeance K70 Wired Gaming Keyboard ($129.99 @ Amazon)
Mouse: Corsair Vengeance M65 Wired Laser Mouse ($57.53 @ Amazon)
Headphones: Corsair Vengeance 2100 7.1 Channel Headset ($99.99 @ Amazon)
Total: $2400.83
(Generated by PCPartPicker 2014-05-09 19:14 EDT-0400)
Total silence is what you'll get from this system.
I noticed the change in the motherboard, memory, video card, and storage
I'll try to keep my questions short and to the point;
1 If I'm willing to spend it, will additional RAM be worth the $$
2 I don't think there is a difference in the video card performance as it has the same chipset as the one I picked. can you verify?
3 I am most confused about the motherboard, it seems like the one you picked has much fewer features. I'm not looking to pay for a bunch of things I don't need, so whats the biggest (noticeable) difference between the two parts?
thank you for your time!
1. Unless you're going to be doing video editing or rendering, then anything more than 8GB will be useless. Most games today will use a maximum of 6GB anyway.
2. They're both the same card, the only difference may be the cooling, but Zotac is a pretty decent brand and the performance you get from running these two cards in SLI will still destroy many other cards out there. The 770 I've selected is a pretty good one, and if you overclock them yourself, you can get them to the performance of the other one's you've selected.
3. Well, the ASUS board I've selected for your is the correct socket with the newly upgraded CPU, as the 4770K is LGA 1150, while the other one was LGA 1155. This Z87 board does come with less features, but it is a solid, reliable motherboard. There is basically no difference between the two motherboards except for the extra features on the old board, but if you really need them, then you can find another 1150 board like that. I just recommend this one because it's in a good price bracket and gets the job done. (also have I mentioned that I think it looks hella good?)
and no problem.
