Hi there, i'm new around here. I was wondering if someone could check my build out and see if everything would be good and in tip top shape? I will be doing a lot of video editting in the future and as well as some pc gaming @ about 1080p. Some things I would like to know would be if this would be somewhat future proof, would I be able to add more than two monitors in the future, would I have room for expansion in this case and other recommendations? Also, I am trying to keep the budget under $1300. Thanks.
CPU: AMD FX-8350 FX-Series Black Edition
MoBo: ASUS M5A99FX PRO R2.0 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
GPU: EVGA GeForce GTX670 FTW+
PSU: Corsair Enthusiast Series TX 750 Watt
CPU Cooler: Antec Kuhler H2O 620 Liquid CPU Cooler System
HDD: Seagate Barracuda 7200 1 TB 7200RPM SATA 6 Gb/s NCQ 64MB Cache 3.5-Inch Internal Bare Drive ST1000DM003
RAM: Corsair Vengeance Blue 16GB (4x4GB) DDR3 2133 MHz (PC3 17000)
Case: Cooler Master HAF 912 - Mid Tower Computer Case with High Airflow Design
CD/DVD Drive: Asus 24xDVD-RW Serial ATA Internal OEM Drive
Wireless Network Card: TP-LINK TL-WDN4800 Dual Band Wireless N900 PCI Express Adapter
Computer Case Fan: Cooler Master MegaFlow 200mm Red LED
