Hi. I have a budget of ~700-800 dollars and this is my first attempting at building a PC. Are all the parts compatible with each other and is there anything else/or better alternative that I should be getting? Any help would be greatly appreciated. Thanks
Case
Rosewill Chalenger
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
POWER SUPPLY
OCZ ModXStream Pro OCZ700MXSP 700W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341018
Processor
AMD Phenom II X4 965 Black Edition
http://www.newegg.com/Product/Product.aspx?Item=N82E168191037271
Motherboard
ASRock 880G EXTREME3
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157191
Memory
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
Graphics Card
EVGA 768-P3-1362-AR GeForce GTX 460 (Fermi) Superclocked 768MB 192-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130564
Hard Drive
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5"
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
Dvd Burner
LG Black 22X DVD+R 8X DVD+RW 22X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 22X DVD Burner - Bulk LightScribe Support - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136168
Case
Rosewill Chalenger
POWER SUPPLY
Processor
Motherboard
Memory
Graphics Card
Hard Drive
Dvd Burner
