First Time Build Advice Requested
Hyph2798
Commendable
Apr 12, 2016
Hi, I am about to purchase the parts for my first build and would like a second opinion on this before doing so, but I also have a few questions that I would like to be answered also before I do purchase this:
CPU: AMD FX-6300 3.5GHz 6-Core Processor (£82.85 @ Amazon UK)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler (£27.99 @ Amazon UK)
Motherboard: Asus M5A78L-M/USB3 Micro ATX AM3+ Motherboard (£50.31 @ Amazon UK)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1866 Memory (£29.99 @ Amazon UK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (£39.84 @ Amazon UK)
Video Card: Gigabyte GeForce GTX 950 2GB Dual WindForce Video Card (£129.66 @ Amazon UK)
Case: CiT SPECTRE WHITE ATX Mid Tower Case (£33.99 @ Amazon UK)
Power Supply: Corsair VS 550W ATX Power Supply (£36.99)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter (£24.99 @ Amazon UK)
Total: £456.61
Generated by PCPartPicker 2016-04-12 16:02 BST+0100
I do plan on Overclocking this build hence why I have included the 212 EVO Cooler, I have checked that it does fit with this case as on PCPartPicker it says it may not fit but I have been assured it does.
  • Firstly, is the motherboard good enough to be able to hand the OC on the CPU or do you recommend upgrading this? I will only be able to spend an extra £20 on this though as I am almost at my budget.
    Secondly, with the Overclocking in mind, I will mainly be playing WoW but also games such as H1Z1, Fallout 4, etc, will this CPU & GPU be able to handle these games on at least Med Settings but WoW at High Settings with a Constant 60FPS @ 1080p?
I already have the OS and Monitor with me hence why it is not included in the list.
Thanks for any help in advance.
DO NOT GET AN FX 6300 FOR WOW
an i3 6100 will MASSIVELY outperform an FX cpu in a game like WOW or any blizzard game.
The i3 6100 has stronger cores. WOW uses 2 cores
The fx6300 has 6 cores but they are much weaker.
More cores will not help your performance in a game that only uses 2 cores.
that would be like getting a 4 gtx 750ti SLI over a gtx 970 in a game that doesnt support SLI lol
I do not like seeing fellow gamers get the wrong hardware for the games they play and get bad performance for the money they spent.
You will have a much higher minimum FPS on wow with an i3 6100.
The i3 6100 outperforms the fx 8350 in a game that USES all 8 cores (BF4)
you can overclock that fx 6300, but this build is even faster than an fx8320 in gaming.
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor (£97.98 @ Ebuyer)
Motherboard: Gigabyte GA-B150M-DS3H Micro ATX LGA1151 Motherboard (£63.30 @ Ebuyer)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory (£32.88 @ Ebuyer)
Video Card: EVGA GeForce GTX 950 2GB Superclocked+ ACX 2.0 Video Card (£129.98 @ Novatech)
Power Supply: XFX TS 550W 80+ Gold Certified ATX Power Supply (£62.64 @ Amazon UK)
Total: £485.60
Generated by PCPartPicker 2016-04-12 16:42 BST+0100
Hi Thanks for the suggestion, I would prefer to stick with the FX6300 if im honest, would it be able to run WoW on atleast High settings @ 1080p when overclocked? I had changed around the Mobo and PSU a bit as after posting i saw the Mobo may not be so great when OC'ing the FX 6300
would this be better:
Motherboard: Gigabyte GA-970A-DS3P ATX AM3+ Motherboard (£52.99 @ Amazon UK)
Power Supply: Corsair Builder 500W 80+ Bronze Certified ATX Power Supply (£44.71 @ Amazon UK)
Total: £467.01
Generated by PCPartPicker 2016-04-12 17:38 BST+0100
Thanks.
im sorry but youre soo soooo stupid for sticking to a fx6300.
the i3 6100 outpeforms the 8320 same price(yes in wow too even if u oc that 8320 or 6300)).
no amd chip wont bottleneck high end graphic cards.
yes u read that correctly.
why wont u get a better system for the money????
your money do with it whatever u want.
yes the
