First time build HELP!
Jonindo
7
So I've decided to build my first gaming PC from scratch and i was just wondering if these parts would be compatible with each other. I'm mostly just concerned whether there would be enough power supplied to the components from the 750W PSU and the compatibility between the VGA and Mobo. thanks! :bounce:
Motherboard: MSI Z77A-G43 Z77 1155 4xDDR3 RAID SATA3 USB3 HDMI DVI ATX Motherboard (http://www.msy.com.au/product.jsp?productId=9762)
CPU:Intel BX80637I53470 i5-3470 3.2/3.6GHz LGA1155 IVY Bridge Boxed CPU Cores 4/6MB
(http://www.msy.com.au/product.jsp?productId=9376)
RAM: Patriot Gamer2 PGD38G1333ELK 8G Kit(4Gx2) DDR3 1333
(http://www.msy.com.au/product.jsp?productId=7283)
HDD:Seagate 3.5" Barracuda 500GB ST500DM002 SATA3 7200RPM 16MB HDD
(http://www.msy.com.au/product.jsp?productId=8477)
Graphics card: Gigabyte GV-N65TOC-2GD 2GB GTX650 TI PCI-E VGA Card
(http://www.msy.com.au/product.jsp?productId=9715)
Optical Drive: ASUS Black/24x DVD-RW Writer Retail Packing
(http://www.msy.com.au/product.jsp?productId=8711)
CASE: A-Power APWR-C-MGX2 Megatronx2 Case with PSU (750 WATT)
(http://www.msy.com.au/product.jsp?productId=9560)
nix327
417
What is your budget?
nix327
417
The z77 motherboard is meant for overclock and the 3470 cpu cannot be overclocked..we need to know your budget, monitor resolution and what kind of gaming you intend to do with this build?
nix327
417
PCPartPicker part list: http://pcpartpicker.com/p/sJdL
Price breakdown by merchant: http://pcpartpicker.com/p/sJdL/by_merchant/
Benchmarks: http://pcpartpicker.com/p/sJdL/benchmarks/
CPU: Intel Core i5-3470 3.2GHz Quad-Core Processor ($149.99 @ Microcenter)
Motherboard: ASRock H77 Pro4-M Micro ATX LGA1155 Motherboard ($89.99 @ Amazon)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($41.99 @ Newegg)
Storage: Samsung 830 Series 128GB 2.5" Solid State Disk ($119.00 @ B&H)
Video Card: Gigabyte Radeon HD 7870 2GB Video Card ($229.99 @ Newegg)
Case: Antec Three Hundred Two ATX Mid Tower Case ($59.71 @ NCIX US)
Power Supply: Antec High Current Gamer 520W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($79.99 @ Amazon)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($24.98 @ Newegg)
Total: $785.64
(Generated by PCPartPicker 2012-12-16 03:46 EST-0500)
Its about 800$ without OS..but its worth the money. If you do want to bring down the cost a bit just let me know.
nix327
417
I forgot to add an HDD..sorry about that..i made some changes and now its about 800$ with the OS.
PCPartPicker part list: http://pcpartpicker.com/p/sJlA
Price breakdown by merchant: http://pcpartpicker.com/p/sJlA/by_merchant/
Benchmarks: http://pcpartpicker.com/p/sJlA/benchmarks/
Motherboard: ASRock H77M Micro ATX LGA1155 Motherboard ($69.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($69.99 @ NCIX US)
Case: Cooler Master Elite 430 ATX Mid Tower Case ($41.98 @ Amazon)
Power Supply: Antec Neo Eco 520W 80 PLUS Certified ATX12V / EPS12V Power Supply ($58.98 @ Newegg)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($17.89 @ Outlet PC)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) ($89.98 @ Outlet PC)
Total: $760.78
(Generated by PCPartPicker 2012-12-16 04:14 EST-0500)
nix327
417
Not to worry..we can still reduce the price without bringing down performance..this build is about 660$ without the OS..
PCPartPicker part list: http://pcpartpicker.com/p/sJpj
Price breakdown by merchant: http://pcpartpicker.com/p/sJpj/by_merchant/
Benchmarks: http://pcpartpicker.com/p/sJpj/benchmarks/
Memory: Mushkin Blackline 8GB (2 x 4GB) DDR3-1600 Memory ($35.57 @ NCIX US)
Video Card: Sapphire Radeon HD 7870 GHz Edition 2GB Video Card ($194.99 @ Newegg)
Case: NZXT Source 210 (Black) ATX Mid Tower Case ($29.99 @ Newegg)
Power Supply: XFX 550W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($49.99 @ NCIX US)
Total: $708.38
(Generated by PCPartPicker 2012-12-16 04:30 EST-0500)
Jonindo
7
Im trying to take these parts with what i can get from MSY, because it's the only shop i can get these parts from in my district and alot of these parts, they don't have at MSY
The build i stated earlier was about the best i could get from MSY in my price range
nix327
417
cpu: http://www.msy.com.au/product.jsp?productId=9552- $180
mobo: http://www.msy.com.au/product.jsp?productId=9135- $62
ram: http://www.msy.com.au/product.jsp?productId=8835- $44
hdd: http://www.msy.com.au/product.jsp?productId=8903- $74
optical drive: http://www.msy.com.au/product.jsp?productId=8711- $23
gpu: http://www.msy.com.au/product.jsp?productId=9811- $195
case: http://www.msy.com.au/product.jsp?productId=878- $63
psu: http://www.msy.com.au/product.jsp?productId=9674- $63
total: $ 704
If want to reduce cost then get the i3 3220..but i recommend you go with the i5 3470
http://www.msy.com.au/product.jsp?productId=9550
