First time build help
just pete
12
I've been browsing the forums for a few days looking for ideas and reviews, and I've finally decided to register and ask opinions. I've been using hand-me-down systems and components for some years now, and I've finally got some money to build somethign myself. It's not much, but I want to see what I can do with it, as the current system (Dell Dimension 5100) has given up the ghost.
My budget is $425. I have some components that I can reuse, and hopefully I'll have enough to do the rest. Here's what I have available:
2 250GB SATA drives (SATA 1, one is a Maxtor and the other is a Seagate) - sticking with these. I'd like to RAID them, if it's within the budget, but it's not a show stopper.
Geforce 6800GT 512MB - I'm sticking with this for now, will upgrade it at a later date
2 GB (2x1GB) PC25300U memory
Case from the Dimension 5100, with a 305Watt PSU (probably don't want to reuse the case, but it's an option to save cash).
Case from a Dell Precision 470, with a 550Watt PSU (proprietary) - this one would be easier to use, but not sure that it's ATX compatible.
I already have a choice of operating systems (Win XP pro and Vista Ultimate)
With these components, I'd like to purchase a proccessor and mobo (plus whatever else) to bring me up to speed. I've narrowed down my processor choices to the following:
AMD Phenom II X3 720 2.8GHz
- or -
Intel Core 2 Duo E8400 Wolfdale 3.0GHz
I know, I know, Intel vs. AMD debate flamebait, but I'm seriously trying to determine which would be best for my purposes. Considering that I have 2 main criteria for this system, I'm not sure which way to jump. This system needs to play CIV IV BTS on the highest settings, but also needs to double as my home work system - meaning it has to run several different office-related programs concurrently (I generally work with a minimum of 10 windows open).
I'm still researching motherboards, suggestions appreciated!
theAnimal
2,370
AMD Phenom II X3 720 & BIOSTAR TFORCE TA790GX 128M AM2+/AM2 AMD 790GX HDMI ATX AMD Motherboard - Combo $211
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.165025
BFG Tech LS SERIES LS-550 550W @ 40°C ATX12V 2.3 / EPS12V 2.8 SLI Certified CrossFire Ready 80 PLUS Certified Active PFC Power Supply - Retail $80
http://www.newegg.com/Product/Product.aspx?Item=N82E16817702008
Antec Three Hundred Black Steel ATX Mid Tower Computer Case - Retail $60
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
Pioneer Black 2MB Cache SATA 20X DVD±R DVD Burner - OEM $26
http://www.newegg.com/Product/Product.aspx?Item=N82E16827129032
just pete
12
Oh, almost forgot. As an alternate build, I have access to a pair of E5150 Dual-Core Woodcrest processors, and enough 4GB PC2-5300 FBDIMMs to fill out any dual-socket LGA771 mobo. I'm thinking this may be a viable alternative, as I can afford the more expensive 'server-class' mobo if I'm not paying for the processors. What think ye?
just pete
12
Thanks,Animal - you made me notice another thing I don't need - I've got more CD/DVD/RW drives than I can shake a stick at. I don't do much in the way of burning anyway, so what I've got there is sufficient. Does this change the options any?
theAnimal
2,370
I would suggest 4GB of DDR2 800 or 1066.
