Hello! I'm attempting my first build and would like to ask the forum for some suggestions and advice on hardware.
My understanding of forum jargon is a little limited - but I can follow most of what i read in most of the posts on TH.
I might be starting from the wrong place, but I saw the Lian Li PC-C36B case on NewEgg and really would like to build around it. I know there are some limitations to consider when using this case, and only certain hardware configurations work correctly - i.e. Micro ATX, specific pci slot layout. Any help is sincerely appreciated!
Ideally I'm looking to build a music/video server, storage, VM server. No gaming, no overclocking.
ADDITIONAL COMMENTS: To save money I was considering built-in graphics. I heard that an AMD 780G or AMD 790GX motherboard might work well. Are any Intel boards similar for integrated graphics at a good price? Should I forget the Lian Li b/c of hardware config limitations? Is the bundled 300w PSU lightweight?
APPROXIMATE PURCHASE DATE: Today
BUDGET RANGE: US$600-$700
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: File server, home entertainment, VM Server
PARTS NOT REQUIRED: keyboard, mouse, monitor, speakers, OS
PREFERRED WEBSITE(S) FOR PARTS: newegg.com
PARTS PREFERENCES: Lian Li PC-C36B http://www.newegg.com/Product/Product.aspx?Item=N82E16811112185, Western Digital Caviar Black WD1001FALS 1TB 7200 RPM SATA 3.0Gb/s 3.5" Hard Drive - OEM http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284
OVERCLOCKING: No
Thanks for any suggestions!
OVERCLOCKING: No
