First time build.. Need help choosing parts
Tin88
94
Purchase date:Next couple weeks
Budget:$850-1050
System usage:Gaming, media, movies, surfing the internet, school
Parts not required-Mouse and keyboard, Case, OD, HD, CPU Fan
Preferred website: Newegg only
Country of Origin: USA
Parts Preferences: Intel CPU 2500k, Asus mobo, Nvidia GPU unsure on model
Overclocking:yes
Sli:maybe
Monitor Resolution:1920x1080
Additional info:I am looking for a good low/mid range monitor 20-23 inch. for internet surfing, some gaming will most likely use my 42" plasma for gaming also. I will be reusing my OWC 120GB SSD from my macbook pro that i am selling
_____________________________________________________________________________________
CPU: Intel Core i5-2500K Sandy Bridge- $219.99
http://www.newegg.com/Product/Product.aspx?Item=19-115-072&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=5&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Page=2#scrollFullInfo
Mobo: ASUS P8Z68-V PRO LGA 1155 Intel Z68 $159.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131730R
Ram-I've been looking at these but dont know voltage is right....
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100006519%2050008476%2040000147%20600006050%20600006127%20600052012%20600000261&IsNodeId=1&name=1.5V&Order=PRICE&Pagesize=100
GPU:Nvidia- Im stuck between 560 ti prob. SLI and 570
560 ti-
http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=40000048&IsNodeId=1&Description=gtx%20560%20ti&bop=And&CompareItemList=48|14-127-594^14-127-594-TS%2C14-125-363^14-125-363-TS%2C14-130-651^14-130-651-TS%2C14-127-565^14-127-565-TS%2C14-130-610^14-130-610-TS
570-
http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=40000048&IsNodeId=1&Description=gtx%20570&bop=And&CompareItemList=48|14-127-582^14-127-582-TS%2C14-125-382^14-125-382-TS%2C14-130-620^14-130-620-TS%2C14-130-595^14-130-595-TS
PSU:Antec High Current Gamer Series HCG-900 900W One of only a few with multiple 12V+ rails $110
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371050
Monitor- 1080p HDMI input connection.. Do i want LED backlight? Speakers in the Monitor??
Heres a few within the range i wanna spend...
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009255
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236059
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009278R
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236111R
http://www.newegg.com/Product/Product.aspx?Item=N82E16824005250
http://www.newegg.com/Product/Product.aspx?Item=N82E16824228042
Thanks in advance...
AdrianPerry
CPU - i5-2500k = Good choice
GPU - SLI 560Ti's are nice, however in the long term you would get more performance from buying a single GTX 570 now and adding another in SLI later on.
Motherboard - ASUS P8Z68-v PRO = Good choice, i use one myself
PSU - Generally a single rail is preferred rather than multiple rails. 750w would be plenty for SLI 560Ti's and 850w would be plenty for SLI 570's. Suggested brands to look at are: Corsair, XFX, OCZ, SeaSonic, Antec - also recommend looking for a modular PSU.
RAM - You need 1.5v RAM for Sandy Bridge 1155 motherboards.
HDD - Not listed? (Not required)
Case - Not listed? (Not required)
Optical Drive - Not listed? (Not required)
The number of rails on a modern PSU does not matter. In fact, I'd rather have more than one, with properly configured OCP. Otherwise, a near-short on a single rail may just appear to be a heavy load, and the PSU won't shut down, but something will get smoked or even start a fire.
Tin88
94
So you u think 570 would be good? i want it to kick ass and run max settings for BF3, MW3, Black Ops, Need for speed games.. pretty much nething besides metro 2033 or crysis 2.
Also HD and Optical drive not required im just gonna get a 1tb drive combo deal from newegg.
As for the case im lookin spend no more then $100 on it i will go higher i if see one i like, prefer a case with a window. Case must be setup for liquid cooling and have plenty of fans for good airflow. Also prefer one with red neons but thats not a deal breaker
AdrianPerry
For liquid cooling your probably looking more at cases like Corsair 650D/800D - these both come in way above $100 though
GTX 570 would run CRYSIS and METRO maxed out with at least 40fps and i presume it will perform in a similar manner, if not better, with BF3, SKYRIM ect.
Tin88
94
Which would u recommend outta these or any other 570?
And ur running just one 560 ti?
AdrianPerry
All the 570's listed are reputable cards. EVGA is a popular choice.
Im running a single 560Ti overclocked to 950MHz with 5 case fans on a CoolerMaster Storm Scout - i wouldn't say the build is noisy, during the day i dont even notice it, but its not exactly silent either. I wouldnt like to try sleeping with it left on overnight, might be a little disturbing.
Tin88
94
For the Ram...Can i overclock it myself or do i have to buy it overclocked?
AdrianPerry
I've never actually tried overclocking RAM.
Personally i bought XMP 1600MHz RAM and then just enabled XMP in the BIOS.
I'd have a look on google for a quick guide on overclocking RAM and by how much you can overclock it. Just keep in mind socket 1155 motherboards require 1.5v RAM, not 1.65v (as this has caused some issues).
Tin88
94
Im looking at changing motherboards to something more affordable(open box deal is out of stock). What would i use extra PCI, PCI-E slots for besides GPU? Im a noob to computer builds do i really need a mobo with with multiple slots if i dont plan on using SLI? Also would 16GB ram be overkill? Even 12GB too much? I have a dual core 2.7GHz macbook pro with 8GB and 120GB SSD and it still seems slow(my guess is cuz its a slower dual core). Third thing what size SSD would be sufficent/recommended for SSD Cache for my 1TB spin drive??
Tin88
94
Tin88
94
Tin88
94
Have you used either brand? I was looking at Asus I like the Bios program they have for overclocking/tuning the system. It seems to be one of the better ones especially for someone like me who has no experience with overclocking. What about this one vs. what you posted...
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131786
Maybe this one...Idn if I really need Bluetooth or not....
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131729
Tin88
94
Tin88
94
Which PSU would u recommend?
http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=100007657%20600014024&IsNodeId=1&bop=And&ShowDeactivatedMark=False&CompareItemList=58%7C17-171-048%5E17-171-048-TS%2C17-153-106%5E17-153-106-TS
Also, how do u have ur 5 case fans set up? are they always on or do u have a fan controller? are they PWM fans?
Im looking at getting the Cooler Master 692 Advanced. I was originally looking at the CM Storm Enforcer but it only has the option for 4 fans vs. the 10 max on the 692 Adv.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119216
Thanks again
Tin88
94
How do u have ur fans hooked up? Fan controller? Or r they always running?
Only the front fan has a control knob. It is an intake. The top and rear run at full speed. The PSU draws in its own air from beneath the case (I have it on a board, not on the carpet).
The rear fan is quiet too, so it must also be low-speed. I can hardly hear it when it is on.
Tin88
94
Y have it on a board? Keep dust and what not from carpet??
Better airflow. It's like sticking head down face first in a pillow vs face first on a hardwood floor. Your not going to be able to breathe in the pillow, but you will on that hardwood floor.
No air, no cooling.
jelson
14
I took at good look at the NZXT H2 case (looked quite interesting in person at Frys Electronics) but airflow isn't all that great with the front door closed and it only opens 90 or so degrees. Here is a review of it.
I ended up getting the Storm Snipe (couldn't say no to ShellShocker promo price)
I saw the Cooler Master HAF 922 at Fry's too and rather liked it.
