ok so i just built my rig
and ive been running Speedfan and some programs to max out my cores to test my Temps. BTW here is my rig.
Thermaltake M9 Mid Tower Case.
4 120mm Case fans. 2 Blowing in on the side panel 1 blowing in from the front and 1 blowing out in the back.
BIOSTAR Tseries. TA790GX A2+
AMD Px4 9850 BE 2.5GHz Quad Core
8GB A-data DDR2 RAM 800 MHz with Head spreaders Four 2GB chips.
320GB Western Digital HD 7200RPM
Samsung DvD Burner with Litescribe
Antec 850Watt PSU ( 80% CTF )
EVGA GTX 260 896MB GPU
Windows Vista 64-bit SP1
anyway
my idle Temp is 40c-45c and under load i can see 50-55c maybe higher. i have the Stock 9850 Heatsink and fan installed. now i was thinking about buying the Zalman 9500a and Arctic Silver 5 Thermal Compound but im not sure how i install it. stock was just pop on and go but im not sure how to install the TC and do i need to take that back plate off the Mobo or not. anways could someone school me a bit. should i get the new HSF? or are them Temps ok? or should i change the Config of my Fans? thanks blaze.
* Edit * oh and FYI i dont plan on overclocking this system at all. i dont trust my self lol and i find the system to run fast so im fine with current speeds. also until someone replies im almost scared to run any games lol of fear of 55c temp 😵
and ive been running Speedfan and some programs to max out my cores to test my Temps. BTW here is my rig. Thermaltake M9 Mid Tower Case.
anyway
