Approximate Purchase Date: As soon as possible I’ve waited long enough (tonight!)
Budget Range: $1200 Before Rebates
System Usage from Most to Least Important: CS5 Master Suite (Photo and Web Editing), AutoCad 2011, Gaming (would like to be able to game (Diablo 3) no FPS.)
Parts Not Required: Boot Drive, CPU, keyboard, mouse, monitor, speakers, OS
Preferred Website(s) for Parts: Newegg.com (First choice), Tigerdirect.com, Amazon.com
Country of Origin: USA
Parts Preferences: Name Brands
Overclocking: Yes (once I read up on it more)
SLI or Crossfire: Maybe
Monitor Resolution: 1920x1200 X 2
Additional Comments:
Please comment and steer me in the right direction. Below is my first attempt at a build after reading these forums.
Motherboard:MSI P67A-GD65 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard ($179.99) Only good motherboard that seems to be in stock.
CPU: Intel Core i7-2600K Sandy Bridge 3.4GHz 8MB L3 Cache Quad-Core Processor (Already have)
CPU Cooler: Please recommend one!
Thermal Compound: Arctic Silver 5 Thermal Compound - OEM ($11.99)
Video Card: SAPPHIRE 100312SR Radeon HD 6950 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity ($276.99) Unsure if this would be a good card for both gaming cad and CS5. Please recommend.
Ram: G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL8D-8GBXM ($99.99) After promo code. Should i get another 2X4GB stick set?
Case: Antec Three Hundred Black Steel ATX Mid Tower Computer Case ($54.95) I like the case because it is simple and smaller but I don't know much about cases. Will it fit all my components with room for expansion?
Power Supply:CORSAIR CMPSU-850TX 850W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready Active PFC Power Supply ($139.99) (In case I want to SLI or Crossfire in the future) I may be overdoing it please recommend.
Boot Drive: Intel X25-M SSDSA2MH080G2K5 2.5" 80GB SATA II MLC Internal Solid State Drive (SSD) (Already Have)
Secondary HD: SAMSUNG Spinpoint 1TB 7200 RPM 32MB Cache SATA Internal Hard Drive ($65)
Disk Drive: LG WH10LS30 10X Blu-ray Burner - LightScribe Support - Bulk - OEM ($89.99)
Total thus far: $1018.88
Missing from my build: CPU Cooler
Thank you all for your comments and help.
