Question First time builder, having issues with no display
Nov 22, 2022
I'm pretty new to this, but I've been following guides online. This video helped quite a bit. I'm hoping my issue is just inexperience and not something busted.
Everything seems to be working, and I followed the guides as best I could to ensure everything was plugged in.
PC Parts Used for this build. It's all completely new items except the ram.
Tried multiple monitors and hdmi cables, as well as display port. Could I be missing a cable?
Here's an imgur post of the Motherboard
I'm attempting to find a way to update the bios, but there doesn't seem to be a button for it on the MSI 320m pro-vh plus.
I assume you plug your cables into your gpu? If not your cpu has to have integrated grpahics and you have to enable it in the BIOs since your gpu will automatically disable it. You can search for a video that explains how to do it. But if i was you i would plug it into the gpu.
Yes, it's plugged in and clicked into place. It just doesn't have PCIe slot on the gpu.
I misunderstood. Yes, I've tried the ports on the gpu.
