First time builder need help
Simon_118
4
Hey guys, after having played games on my 2011 macbook for 6 years i have finally gotten myself together to build my very first gaming pc ! 🙂
I have researched and read quite a bit about the basics and all the parts, but i need some help to check for bottlenecks and other rookie mistakes 🙂
This is the build i had in mind:
CPU:
Intel i5 Quad-Core i5-6600 3.3GHz Processor
https://www.amazon.co.uk/gp/product/B0136JONRM/ref=ox_sc_act_title_5?ie=UTF8&psc=1&smid=A3P5ROKL5A1OLE
Gpu:
EVGA 3GB GeForce GTX 1060
https://www.amazon.co.uk/gp/product/B01L31DAQK/ref=ox_sc_act_title_12?ie=UTF8&psc=1&smid=A3P5ROKL5A1OLE
RAM:
Corsair CMK8GX4M2A2400C14 8 GB (2 x 4 GB) Vengeance LPX DDR4 Memory Kit
https://www.amazon.co.uk/gp/product/B00S51XM5Q/ref=ox_sc_act_title_11?ie=UTF8&psc=1&smid=A3P5ROKL5A1OLE
Motherboard:
Gigabyte GA-Z270P-D3 7/6th Generation Motherboard - Black
https://www.amazon.co.uk/gp/product/B01NCS9QS5/ref=ox_sc_act_title_10?ie=UTF8&psc=1&smid=A3P5ROKL5A1OLE
Cooler:
Cooler Master Hyper 212 LED Air CPU Cooler
https://www.amazon.co.uk/gp/product/B01KBXKP8W/ref=ox_sc_act_title_9?ie=UTF8&psc=1&smid=A3P5ROKL5A1OLE
Power:
EVGA 430W PC Power Supply
https://www.amazon.co.uk/gp/product/B00GP5Y5HI/ref=ox_sc_act_title_8?ie=UTF8&psc=1&smid=A17AS5ETPMZ9A1
Case:
Corsair CC-9011051-WW Carbide Series SPEC-02 Windowed Mid-Tower ATX Gaming Case
https://www.amazon.co.uk/gp/product/B00I0MKMG2/ref=ox_sc_act_title_7?ie=UTF8&psc=1&smid=A3P5ROKL5A1OLE
SSD:
Crucial MX300 275 GB SATA 2.5 Inch Internal Solid State Drive with 9.5 mm Adapter
https://www.amazon.co.uk/gp/product/B01IAGSD5O/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A3IRU7Q642HWMA
I mostly play Wow and Lol, since my old macbook cant really cope the more demanding games.
Thanks in advance! 🙂
Simon
Sorry, I assumed you were in the UK :)
Cooler - The one that...
That's a good start mate, what's your total budget for this build?
- I would drop the cooler as you'll get one in the box with the i5
- You could get a cheaper motherboard too if you wanted
- The 525GB MX300 isn't much more than the 275 so you should definitely consider it
My budget is around 1150 pounds, but that is including a monitor 🙂 im thinking of getting a 24", 1ms, 144hz..
- Isnt it smart to get an extra cooler, or is it enough with the one that comes with the Cpu?
- I will try to look for another Mobo then, Thanks! 🙂
- I would like another Ssd, but the ones that i have looked at doesnt ship to my country so i might get that from the .com page
Cooler - The one that comes with the CPU is more than enough :)
Mobo - This one should do just as good: https://www.amazon.co.uk/dp/B01N2Y2GLP/?tag=pcp0f-21
No worries, thanks a lot for helping! :-D
