1st time posting her and 1st time building and I'm going for kind of a higher-end budget build if that's even a thing.
PC Specs : http://pcpartpicker.com/p/nmKT6h
ps. There is no case that I'm planning to use on the pcpartpicker so I used the Z3 as a place holder and my budget is around 750-800
So I have a few questions :
1. Is the GTX 970/R9 390 + i5 4460 a viable option ?
2. Is this a good enough PSU for this system and this GPU (some say its not some say it's ok and pcpartpicker says it's ok apparently)
3. If that GPU+CPU isn't a good combo / if that PSU isn't good enough what should I use as replacement.
4. Im planing on using the Zalman R1 (not the Z3) so will the Sapphire 390 fit into the case.
Sorreh for the wall of text.
