Hi! This is my first time building a PC and would love some feedback before buying anything. Below are the links to the parts I am thinking about getting. I have outlined some goals for the PC and some questions/concerns I have with the current parts I have chosen. I welcome any feedback you can give me. Example would be if I am missing parts, parts aren't compatible, or better parts exist. Also if you know the answer to any of the concerns that would be great too. Looking forward to your feedback
Parts:
Main Goals for my PC:
Main Concerns:
Parts:
- Primary function to be a great gaming PC
- I want to have 2 USB ports and TRRS audio jack on top of the case for easy access
- Cost between $900-$1300 (not including the graphics card, I already have it)
- Have some cool RGB lighting effects
Main Concerns:
- Can the Motherboard's USB3.2 Gen 1 header be split in two in order to connect with the two USB3.0 connectors on the case top panel? Basically I am asking will I be able to populate the USB3.0 connectors on the case top panel?
- Is there a way with this Motherboard to get TRRS audio from the motherboard to the case top panel TRRS jack?
- Will 550W power supply be enough power?
- Does the power supply come with all the cables I would need?
- Will I be able to split the Motherboard's two aura RGB headers to be a total of four headers so I can control 3 RGB fans in front and one RGB fan in the back?
- Will the CPU Cooler fit in the case?
