First time building a pc, need some help!!!
benalexander
5
Need some reassurance that my build will work and some advice (personal suggestions) on what i should swap out or replace to save money. Hopefully this will play most games 1080p high to ultra settings
Intel Core i5 4670K
Sapphire Radeon R9 280X OC Vapor-X 3GB
ASRock Fatal1ty H97 Performance Motherboard
Western Digital WD Black 1TB WD1003FZEX
SilverStone Strider Plus 1000W ST1000-P Modular PSU
G.Skill Ares F3-1600C9D-8GAO 8GB (2x4GB) DDR3
ASUS DRW-24D3ST 24x DVD Writer
Cougar Volant Black Mid Tower
Ok, so change either the CPU or the motherboard as using an unlocked CPU on a locked motherboard is pointless, look for z97 chipset motherboards. If you are not interested in overclocking then look for an i5 without a 'k' on the end. Your PSU is overkill for your current needs, for a 280x look for something that is close to 600W. Also may I suggest this RAM as its good value currently:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231689&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
An H97 is not locked in any way they just dont overclock as well at Z97 your fine with that cpu and board if you are serious about overclocking a z97 is the best bet but an H97 is fine for some light overclocking.
You have selected a power supply that would power two of you graphics cards. If you aren't planning on Crossfire, then I would drop that to a 750 watt power supply. Given the type of gaming system that seem to be building I would advise a Z87 or Z97 motherboard. I would bump up the RAM to CL9 1866 or faster RAM.
Would upgrading to a ASRock Fatal1ty Z97 Killer Motherboard be a good option? and downgrading psu to Silverstone Strider Gold 750W ST75F-GS?
http://www.guru3d.com/articles_pages/asus_radeon_r9_280x_top_review,8.html
This is Guru3D's generic power supply recommendation for the R7 and R9 series:
AMD R9 280X - On your average system the card requires you to have a 550 Watt power supply unit.
AMD R9 280X Crossfire - On your average system the cards require you to have a 750 Watt power supply unit as minimum.
If you are going to overclock GPU or processor, then we do recommend you purchase something with some more stamina.
Yup i would go down to 500watts if i were you 750 is still wayyy more than enough for your build.
I guess your right thats a stupid card it shouldent need anywere near that much power very unefficent.
