first time building my own gaming pc please help :(
Xenon Senpai
11
I would like to ask for some help here guys cuz its my first time building my own pc and budget is $1500 so I would like to ask if my build is okay? And the games that I play are League of Legends, Skyforge, Guild Wars 2 and probably some other games. I would like to know if I could play these types of games with the highest graphics. Using this build http://pcpartpicker.com/p/PpjZyc
No that new list isn't good that cpu isn't compatible with ddr4 and 32gb of ram for a gaming system is a massive waste of money, even the 16Gb in the build I posted is a bit overkill 8gb is currently enough for gaming.
PSU is an acronym for Power Supply Unit, for SLI you'd want an 850w psu but for a single 980ti 620-650w would be fine.
Its overkill as the hardware is way more powerful than what those games need. Thos games don't have the bigger hardware requirements as games like GTA V and The Witcher 3.
Not bad, but I made a couple of changes and was able to make it better.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($224.99 @ SuperBiiz)
CPU Cooler: Noctua NH-D14 65.0 CFM CPU Cooler ($74.89 @ OutletPC)
Motherboard: Gigabyte GA-G1.SNIPER Z97 ATX LGA1150 Motherboard ($119.99 @ SuperBiiz)
Memory: G.Skill Sniper Series 16GB (2 x 8GB) DDR3-1866 Memory ($94.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($97.89 @ OutletPC)
Storage: Western Digital Caviar Black 1TB 3.5" 7200RPM Internal Hard Drive ($69.49 @ Amazon)
Video Card: EVGA GeForce GTX 980 Ti 6GB Superclocked Video Card ($636.30 @ Amazon)
Case: NZXT H440 Designed by Razer™ ATX Mid Tower Case ($121.99 @ SuperBiiz)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply ($116.99 @ SuperBiiz)
Total: $1557.52
Generated by PCPartPicker 2015-08-09 12:01 EDT-0400
Both system are actually overkill for the games you listed.
I think PSU is overkill. He can save some bucks there and get H100i, as he already wanted.
I figured he had used a 850w in the first build for a future SLI upgrade. the Noctua D-14 performs similarly to the H100 and costs less and you don't have to worry about a pump failure.
Would this also be good? http://pcpartpicker.com/p/zd4sNG
Im sorry for asking but what's an PSU?
And what do you mean by bot systems are overkill for the games i listed?
Sorry for asking cuz I actually don't know a lot about these stuffs. and Thanks again!
Oh I forgot can i also use the NZXT H440 designed by Razer as a case for this one?
THANKS AGAIN! and could you please help me decide which motherboard should i use for this one. THANKS AGAIN!
so for the first build that you posted can i add some fans to make it better and how many should i buy? and can you please tell me what kind and the sizes of the fan. THANKS AGAIN! may I also ask how much is the motherboard for the build that you posted 😀 Thank you so much!
