First Time Building, need PSU suggestions
Robbb18
How is this for a build? I need some suggestions on a PSU, storage
APPROXIMATE PURCHASE DATE: pretty soon, already bought some parts
BUDGET RANGE: 1000$~
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming, also maybe some encoding and streaming from PC/360/tv etc (probably need a capture card but i haven't research it that much)
OVERCLOCKING: Yes
SLI OR CROSSFIRE: no, probably will upgrade graphics in the future but only 1 card.
MONITOR RESOLUTION: 1920x1200
Intel Core i7 920 Nehalem with a Megahalems and 2x 120mm fans
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
ASUS P6T
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131359
OCZ XMP Ready Series 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Voltage Desktop Memory Model OCZ3X1600LV6GK - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227388
8800 GTS EVGA 640mb (link has closest i can find on newegg resembling)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130325
COOLER MASTER HAF 932 Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
looking for a quality PSU to compliment the system. Right now im also looking for a cheap/good deal Hard Drive, doesn't need to be big on size.
But in the future I might try a simple raid, so i want a PSU that will be able to handle those future upgrades too.
I'd really appreciate any advice, tips, etc.
Thanks.
If you can then get the D0 stepping...
Do you have that graphics card ? or you are going to buy one?
Power supply - Corsair 650TX is the best option...
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
or
PC Power & Cooling S61EPS 610W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817703005
And before deciding on the Pro Mega, take a look at this article...
http://www.xbitlabs.com/articles/coolers/display/core-i7-coolers-roundup.html
And as you will not be having more than 1 graphics card, drop to a cheaper mobo like the Gigabyte UD3R...
But if you want performance,, then get this mobo...
ASUS Rampage Gene - It will perform little better than the P6T...
http://www.tomshardware.com/reviews/rampage-gene-lanparty,2302.html
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131386
