First Time Building PC. Thoughts?
jameshaae
Link: http://www.amazon.co.uk/registry/wishlist/2DPI57827IV1Z ive put together a list of parts (minus the OS) that im going to be using for my first ever PC build, which will be around christmas time.
Im not the most experienced of people with the specs and all that of PCs so im wondering what some of you people that know a good bit about it think?
Eg. Some of the games i could run well ect.
Thanks!
Edit: )forgot to say) Are all these parts compatible?
first thought, anti static band = pointless. plug in your power supply before you even start to build and leave it off to the side. then touch it whit both hands every 10 minutes or so, or whenever you are handling a new part or just walked around on some carpet. this will keep you grounded. having an AM3+ board and an APU makes no sense. I would get a FX 4300 for that motherboard. I mistrust that power supply. spending a proper $40 will get a much better one. That graphics card is useless with an APU, but is of use with the FX 4300. I frankly would go for at least a GT 730 as any thing lower will be useless for all games. with a GT 730 you can play minecraft at high settings and CSGO at low medium settings. if you do go with an FM2+...
first thought, anti static band = pointless. plug in your power supply before you even start to build and leave it off to the side. then touch it whit both hands every 10 minutes or so, or whenever you are handling a new part or just walked around on some carpet. this will keep you grounded. having an AM3+ board and an APU makes no sense. I would get a FX 4300 for that motherboard. I mistrust that power supply. spending a proper $40 will get a much better one. That graphics card is useless with an APU, but is of use with the FX 4300. I frankly would go for at least a GT 730 as any thing lower will be useless for all games. with a GT 730 you can play minecraft at high settings and CSGO at low medium settings. if you do go with an FM2+ board I would get an A8 or better APU.
Thanks!
Agreed! An anti-static wristband is quite a waste of money although it is cheap.
