First Time Desktop Build. Need Help!
Bball124106
23
I am looking at building my first desktop and am looking for some help.
I know all of the basic parts, but the question i have is what to go big on.
I am not a heavy gamer, but just want a fast desktop that i will use with my 50 inch Plasma to browse the internet and stream 1080 movies that i have downloaded.
That being said, I need some major help as this will be my first attempt at doing a build.
Thank you for your help
CPU: AMD A10-7850K 3.7GHz Quad-Core Processor ($169.96 @ OutletPC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.98 @ OutletPC)
Motherboard: Gigabyte GA-F2A55M-S1 Micro ATX FM2+ Motherboard ($34.69 @ Newegg)
Memory: G.Skill Ripjaws Z Series 8GB (2 x 4GB) DDR3-2400 Memory ($84.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($54.98 @ OutletPC)
Case: Rosewill Galaxy-03 ATX Mid Tower Case ($29.99 @ Newegg)
Power Supply: SeaSonic 350W 80+ Bronze Certified ATX Power Supply ($42.99 @ Mwave)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($16.98 @ OutletPC)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) ($89.98 @ OutletPC)
Total: $554.54
this will stream movies 1080p perfectly fine, will be nice and quiet, and can handle some moderate gaming if you want to in the future. i didnt know if you needed windows, so i threw win 8.1 in there just incase.
Approximate Purchase Date: e.g.: 2-3 months
Budget Range: 400-1000
System Usage from Most to Least Important: Internet, 1080 movies, downloading
Are you buying a monitor: No
Parts to Upgrade: All new parts
Do you need to buy OS: Yes
Preferred Website(s) for Parts: open to suggestions
Parts Preferences: I7? is it worth the hype?
Overclocking: Open to suggestions
SLI or Crossfire: Open to suggestions
Your Monitor Resolution: 1080 480Hz 50 inch plasma
Additional Comments: might look at multiple monitors if i go that route, worried about the possiblity of breaking expensive parts considering this is my first build.
And Most Importantly, Why Are You Upgrading: Looking for a new hobby, have some money laying around
You can easily look in the toms forum and find many builds from $600-1000. A $1000 pc will last a long time.
Overclocking/Dual GPUs are more of a hobbyist thing. At $1000, you'd want to build intel, like an i5-4670 if not overclocking and a i5-4670k if overclocking. The r9 280 GPU will probably play any game coming out in the next 2 years on ultra settings. The other components are mostly just looking for good deals and you don't have to look up benchmarks or anything for them.
Here is a simple, reliable, and very FAST regular desktop.
PCPartPicker part list: http://pcpartpicker.com/p/GJnzFT
Price breakdown by merchant: http://pcpartpicker.com/p/GJnzFT/by_merchant/
CPU: Intel Core i3-4150 3.5GHz Dual-Core Processor ($118.98 @ SuperBiiz)
Motherboard: ASRock H97M Micro ATX LGA1150 Motherboard ($75.66 @ Newegg)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory ($73.99 @ Newegg)
Storage: Crucial M500 120GB 2.5" Solid State Drive ($72.00 @ Amazon)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($83.97 @ OutletPC)
Case: Cooler Master N200 MicroATX Mid Tower Case ($39.99 @ Newegg)
Power Supply: Antec EarthWatts Green 380W 80+ Bronze Certified ATX Power Supply ($34.99 @ Newegg)
Total: $499.58
I don't see any reason for you to even get a video card, but if you want one,
PCPartPicker part list: http://pcpartpicker.com/p/BYdLwP
Price breakdown by merchant: http://pcpartpicker.com/p/BYdLwP/by_merchant/
Video Card: EVGA GeForce GTX 750 1GB Video Card ($99.99 @ Newegg)
Total: $589.57
You gave such a broad budget (400-1000) so that means just about anything is an option, but I can't imagine spending more than $600 on core parts for your uses. You may spend a couple hundred on peripherals too.
