Hello. PC noob here. A few months ago I bought a new rig which had a cheap case: Gigabyte C200 Glass. This case comes with one exhaust fan and no intakes. I looked into it now as we're approaching summer, and decided to buy 3 120mm fans which the case supports in the front.
Here's my problem, I'm too bad at putting things together and have no idea how to install it. I can't find the case manual either.
https://ibb.co/0VryG28
Here's a picture of the fan with the screw. It doesn't screw all the way into the hole, it just kinda gets stuck so I'm not sure what to do.
https://ibb.co/ZGj0bJ9
And a picture of the front of the case. I assumed those elongated grooves/openings are where the fans fit, but as I mentioned I can't get the screw to go all the way through the fan screwing holes and into those grooves.
Any help is appreciated.
