R RAVI876P Prominent May 12, 2017 1 0 510 May 12, 2017 #1 Asus X540LA XX439D model laptop I put it for 3 hours charging but it is not starting it command as c:/> so what i do please give some suggestion
Solution rgd1101 May 13, 2017 http://www.amazon.in/Asus-X540LA-XX596D-15-6-inch-i3-5005U-Graphics/dp/B01KLZQ1N8 "it command as c:/>" That it is because you didn't buy one with windows. that the free dos. either buy a copied of windows and install it, get linux, or return the laptop and buy one with windows
rgd1101 Don't Moderator Nov 7, 2011 74,856 4,242 176,290 May 13, 2017 Solution #2 http://www.amazon.in/Asus-X540LA-XX596D-15-6-inch-i3-5005U-Graphics/dp/B01KLZQ1N8 "it command as c:/>" That it is because you didn't buy one with windows. that the free dos. either buy a copied of windows and install it, get linux, or return the laptop and buy one with windows Upvote 0 Downvote Solution
