Hi there, everyone. I am building my very first pc by myself. I have done a ton of research, but would feel so much better with professional advice regarding my decisions. I have just a few questions. Thank you so much!
I thought I should mention as well, that I am building this system for gaming only. Also, I am not interested in overclocking due to inexperience with pc building as a whole. I am just looking for a great system that will be very stable.
On a side note, will this system be powerful enough to run Star Wars: The Old Republic on ultra high settings with high FPS and without any lag?
Thank you so much, I really greatly appreciate any response.
Does this look like it would be a solid system?
Does everything look compatible?
Any improvements to be made?
Can you recommend a case, power supply, and hard drive?
My current build (in theory):
CPU - Intel Core i5-2500 3.3ghz Quad Core
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7073162&CatId=6988
Motherboard - ASUS P8P67 PRO (REV 3.1) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1124780
GPU - MSI N560GTX-Ti Twn Frozr II 2GD5/OC GeForce GTX 560-Ti Video Card
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1318193&CatId=3669
Memory - G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10440897&PID=3891137&SID=rewrite
Operating System - Windows 7 Professional, 64 bit
