First Time PC Builder Mess Up Need help ASAP!
deenosupremo
67
5
5
5
5
5
What are these wires at the last pic? Have no idea where they go.
I feel like I messed up putting the wires in
When putting on Stock heatsink, I put it the wrong way and then forcefully took it out then put it in the right way. Will this mess up the thermal paste?
Also look at the bottom right standoff, used a diff screw and cant unscrew it. Will it matter?
Those wires you're holding in the last pic are for the graphics card. As for forcibly removing your stock fan, I suggest you don't do that again but considering its fresh paste, you probably don't have much to worry about. My advice is that you should be alot more careful next time you do something like this and be a little more prepared. You seem to have made more mistakes than anybody I know whos attempted to put together a PC. I don't know about putting the wrong screw in but theres a reason its the wrong screw.
Well, Im not sure about it being the wrong screw, it fits in the standoff. Its just the big one. I used the mini ones on others.
