First time PC builder! Please help me build the ultimate LoL machine
omarunreal
Commendable
Feb 24, 2016
4
Hi!
After a lot of debate, ive decided to build a computer. I currently have a work laptop which i run LoL on, but I went to my friends house the other day and he was playing on his (3000$) computer and it just looked amazing and crisp and smooth. Now i understand of course I wont get anything near that with my budget, but I am completely new to this so I am not sure which parts to choose.
My same friend mentioned above created a list for me:
http://pcpartpicker.com/p/dTC2pg
My question is, if my budget it $400-500, is there a PC i can build that will be able to play league of legends incredibly smoothly? Or do I have to accept a price range of ~700$?
If there is a pc for that cheap, what parts would i need? A list like the one my friend created would be so much help!
Thank you!
You can build a system that will play LOL very smoothly: i3-6100 + GTX 950
CPU: Intel Core i3-6100 3.7GHz Dual-Core OEM/Tray Processor ($115.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper T2 54.8 CFM Sleeve Bearing CPU Cooler ($16.99 @ Amazon)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard ($47.98 @ Newegg)
Memory: Kingston ValueRAM 8GB (2 x 4GB) DDR4-2133 Memory ($33.35 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($46.89 @ OutletPC)
Video Card: EVGA GeForce GTX 950 2GB SSC ACX 2.0 Video Card ($140.25 @ Newegg)
Case: Cooler Master N200 MicroATX Mid Tower Case ($43.26 @ Mac Mall)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply ($55.99 @ SuperBiiz)
Total: $500.70
Generated by PCPartPicker 2016-02-26 11:55 EST-0500
The above will max LoL perfectly, but I made some minor changes to give it a slightly extra boost and reduce the cost.
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor ($123.88 @ OutletPC)
Storage: Crucial BX200 240GB 2.5" Solid State Drive ($63.99 @ SuperBiiz)
Case: Fractal Design Core 1100 MicroATX Mini Tower Case ($26.99 @ NCIX US)
Total: $492.43
Generated by PCPartPicker 2016-02-26 12:01 EST-0500
With an SSD you'll be loading into matches faster than 90% of the other players.
Thank you so much. I am still debating whether to go with the 700-800$ build my friend made or going for one like you posted. When you say it will "max LOL perfectly" , do you mean it will run it at highest settings with over 100 fps? And will it run smoothly on a 144hz monitor?
Thanks again for the help!
