First-time system build
j_elbers32
14
Here's what I'm currently looking at:
CPU: AMD Phenom II X4 965 Black Edition Deneb 3.4 GHz
Mobo: ASUS M4A79T Deluxe
GPU: SAPPHIRE 100315L Radeon HD 6850
RAM: G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 F3-10666CL7D-4GBRH
PSU: Antec EarthWatts EA650 650W
SSD: OCZ Agility 2 OCZSSD2-2AGTE60G 2.5" 60GB
HDD: Western Digital Caviar Black WD6402AAEX 640GB 7200 RPM SATA 6.0Gb/s
Case: Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case
DVD: ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner
Monitor: ASUS MS Series MS228H Black / Blue 21.5" 2ms(GTG) LED LCD Monitor
OS: Windows 7 Pro for System Builders - OEM
Total (from Newegg): ~$1210 shipped (which is on the upper limit of my current budget , I'd consider up to $1250 if I really missed something). ~$50 in mail-in rebates also, so overall I guess it's ~$1160.
I'm looking at building a new computer primarily for gaming, since my laptop in no way is sufficient for demanding games (primarily Aion for now, I play SC2 but that runs well enough). I'll likely play Diablo III in the future, which I know my laptop won't be able to handle.
Reasons for choices:
1) I like the AMD build over the Intel build primarily for cost reasons.
2) I went with the Radeon HD 6850 over the GTX 460 mainly because there's so few AMD mobos with an NVIDIA North Bridge. And another ~$60.00 for the 6870? Would it really be a significant performance boost?
3) I know the Mobo is a bit of overkill on the PCI-E 2.0 slots, but I like the dual x16 in case I want to XFire later. I know it doesn't have SATA III, but I've read there isn't a big performance boost over SATA II yet. Plus, the SSD uses SATA II. USB 3.0 isn't widespread yet, so I'm not super concerned about that either.
4) I really like the timings on the RAM, plus the price is reasonable. Also, I don't do any major photo editing or anything, so I think 4 GB should be fine?
5) As far as the SSD, I'm likely only going to put Win7 (~20-25 GB?), Aion (~15-20 GB), and maybe Office 10 (down the road, I have Office 2007 on my laptop that I'll use for the time being). So I don't think I need more than 60 GB. If I do need more SSD, I can always RAID another one in the future?
Major questions:
1) The monitor I'm not 100% sure about. Is it worth getting a 2ms response over a 5ms? Or should I go for a 5ms 23" for a similar price instead?
2) I do plan on OCing the CPU (to 3.8-4.0), but I'll likely leave my RAM and GPU alone for now. Will the 650W PSU be sufficient or should I go for the 750W? What about if I plan on XFire?
3) Are there any glaring errors in my build? I feel like it's fairly solid, but I'll definitely consider other recommendations (especially for a cost reduction).
Sorry for the novel, but I wanted to try and give as much info as possible. Thanks for your help!
mosox
Splendid
Mar 31, 2010
5,353
287
That mobo has older chipsets. X8X8 is fine for crossfire, only if you use high-end video cards like the HD 5970 or GTX 480 you need x16x16.
GIGABYTE GA-890GPA-UD3H + AMD Phenom II X4 965
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.524408
Rosewill CHALLENGER + Microsoft Windows 7 Professional 64-bit
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.548000.11-147-153
HDD: Samsung spinpoint F3 500G or 1T
Monitor (get a bigger one, 5ms is fine for gaming)
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236052
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009266
j_elbers32
14
Thanks for the suggestions, I changed the monitor, HDD, and Mobo/CPU (already had the OS as a combo with my SSD).
However, I was looking at the Mobo specs, and the RAM I listed isn't on GIGABYTE's list of supported memory. However, I saw a review of the RAM that listed this same mobo and said it worked just fine. I'm not sure if I should be this nitpicky or not, but it was just something I was wondering about. As long as it would run 7-7-7-21 at 1333, I'd be just fine with it.
Would this one work:
ASUS M4A89GTD PRO/USB3 AM3 AMD 890GX SATA 6Gb/s USB 3.0 HDMI ATX AMD Motherboard
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.526572
mosox
Splendid
Mar 31, 2010
5,353
287
The RAM is fine. Yep, that CPU/mobo combo works too. Check out if the OCZ Vertex 2 isn't better (google: OCZ Vertex 2 vs agility 2) I don't know for sure but I think I remember that the V2 is better or something.
j_elbers32
14
I decided to switch to the V2 (the V2 was even $10 cheaper), bundled with the OS. I think I'm going with the Asus mobo too. Thanks for the suggestions! Any more comments are also welcome!
Similar threads
