My PC is a Gateway DX4860, with fairly good specs (Intel Core i5 @ 3.00 Ghz, 8GB RAM, 1TB HDD), except for the GPU, an ATI Radeon HD 7350 which I think is a 5450 refurbished. I already have my eyes set on the GTX 650 Ti for I have a tight budget. Since it's my first time upgrading and I have little knowledge, I have many questions:
1. Will the new GPU fit into my case? Also, according to this:
2. Which brand should I get? There's EVGA, ZOTAC, Gygabite and ASUS. What's the difference between them?
3. Will I need to change the PSU? I think my PC has a power supply of 300W. Is the PSU a device that goes inside the case? Where is it situated exactly? (like I said, I have little knowledge...
4. Is this the best deal I can get with a budget of maximum $160?
Thank you in advance!
and this :http://www.techpowerup.com/gpudb/632/AMD_Radeon_HD_7350.html
the GTX 650 Ti has different input slots comparing to the 7350.http://www.legitreviews.com/images/reviews/2052/gtx650ti-cards.jpg
)4. Is this the best deal I can get with a budget of maximum $160?
