Hi everyone,
Apologies for bothering, but I really want to make sure that I make it right and I could use some help. For the first time in like 23 years I will be building my own PC and I was able to decide on all of the components apart from the cooling. Now, the cooling needs to be water as the first piece I got was the Aorus RX 6900 XT Waterforce for a very, very decent price. Only then, I realized that it's a watercooled piece and I have no idea about watercooling. This wasn't really an affordable option over 20 years ago. I would really, really appreciate all the help I get from you.
In terms of high-level assumptions:
The build:
Box: Lian Li O11 Dynamic EVO
Motherboard: Gigabyte Aorus Z690 Pro
CPU: i5-12400 (I know, but I just couldn't walk past the affordability, this will be the first thing to upgrade)
GPU: GIGABYTE Aorus Radeon RX 6900 XT Xtreme WaterForce WB 16GB
RAM: Kingston Fury Beast DDR5 5200 2x16GB
Drive: SAMSUNG 980 Pro 1TB
Power: GIGABYTE UD1000GM 1000W 80 Plus Gold
So, I know I need a CPU block for LGA 1700, some tubes, radiators, a reservoir (potentially), a flow sensor (?), pump and obviously some fans. Was thinking about 2x360 (say side and top) with additional 3x120mm fans for intake.
I would like to ask for your advice with regards to the brand and make of the components and also maybe a pointer or two with regards to air flow (what should be installed where and should it intake, or output the air):
CPU Block:
Radiators:
Reservoir:
Pump:
Fans: (how many, which company)
I really, really appreciate you.
Thanks,
Artur.
- I would like to strike a nice balance between performance and price. I've already spent more than I was willing to spend, but hell, when you get to realize your childhood dream, you go for it. If we're going to have to choose though, I would choose performance over 10, or 20 EUR.
- Not sure EK is very popular in my country (Poland), so please if you provide EK as your suggestion, provide an alternative as well.
- I'm not building it to be shiny, couldn't care less about RGB. I mean, I have nothing against it, just don't really care for it.
The build:
CPU Block:
Radiators:
Reservoir:
Pump:
Thanks,
Artur.
