Hey all, I've been thinking about water cooling my computer for a while now and have finally saved up enough money (~$450) to start off. rubix_1011, I read some of your threads and would be glad for your input in my question.
My PC build is as follows:
I would like to cool my CPU only for now as my budget does not allow for the GPUs to be cooled. Plus, it's really hard to find nice looking waterblocks for the 290s since almost no one carries them anymore. So, I decided to wait until I get a better GPU (maybe RX Vega 😀 ) and get a waterblock for it later on. Point of the story, I need a good pump right now so I don't have to replace it later on. I will probably add another 360 rad for the gpu in the future so I hope the pump I picked is enough to go through the loop.
Here's my proposed parts for the loop:
Are these parts compatible/good? Is this pump enough to later support 2 360 rads a gpu and cpu block? Is the XSPC coolant ok? Or should I go for Mayhems/EK? I know the soft tube and barb don't match up but it's really just for draining/filling the loop so I picked the cheapest hose I could find. If there's something cheaper with 1/2 in ID I'd be glad to get it over this. Also, is it better for the res/pump to be connected via a male-to-male fitting or using two g1/4 fittings and some tube (so the pump isn't hanging in the air)? Also, is it ok for the pump to be floating in the air or not? (beneath the res) I'm scared after the vibrations the fittings will slip off and it will fall down. Thanks in advance!
Fractal Design Define S (Windowed)
Asus Z170 Pro Gaming Motherboard
Intel Core-i5 6600K Processor
Asus R9 290 DirectCU II OC
Gigabyte R9 290 Windforce OC (Rev 1.0)
EVGA SuperNove G3 1000W PSU
Seagate 1TB HDD
Kingston HyperX 2666Mhz DDR4 RAM (8gbx1)
Seagate 1TB HDD
Alphacool Eisbecher 250mm Plexi Reservoir ($62.95)
Swiftech MCP50X ($69.99)
XSPC RayStorm WaterBlock V3 ($59.99)
XSPC RX360 V3 ($84.95)
Bitspower None Chamfer PETG Link Tube, 12mm OD, 500mm, Clear, 4-pack ($21.99)
2x Barrow G1/4" to 12mm Hard Tubing Compression Fitting, Black, 4-pack (2x$19.99)
XSPC G1/4" Ball Valve ($11.99)
XSPC G1/4" Threaded T-Fitting ($9.49)
XSPC G1/4" Plug V2, 4-pack ($10.99)
Barrow Male-to-male 4mm Extender G1/4 ($4.99)
Alphacool Silicon Bending Insert for 10mm (3/8") ID, 30cm ($8.49)
XSPC 1/2" ID Barb Fitting with G1/4" Threads 2-Pack ($6.95)
BXQINLENX 3/8" X 1/2" Water Cooling Tubing Hose ($6.98) (FOR DRAIN VALVE)
XSPC ECX Ultra Concentrate Coolant, Blood Red ($11.95)
2x Arctic F12 PWM PST Case Fan, 5 Pack (2x$21.99)
