Hi, so im kind of new here, most of what i do is learning through videos/magazines and i thought since im buying a new processor/mobo combo and i wanted to learn overclocking, that i would try my hand at watercooling to get the most efficient results as possible. I just bought all the parts and i want to make sure i didnt miss anything that i would need, and if my plan sounds good at all.
So heres what i have coming:
Pump/Reservoir Combo (Dual Bay)
240 mm radiator (x2)
GPU and CPU Blocks
g1/4 Compression fittings for 1/2-3/8tubing (x10)
20ft of 1/2-3/8 vinyl tubing
I also got an adapter and some drain plugs for easy draining/flushing in the future, and can set a bleed port on the top if i need it, but in my plan, the reservoir would be the highest piece so i dont know if a bleed port is necessary if i can just do it through the reservoir cap.
As for my plan, i was going to have the Reservoir/pump combo mounted in the top 2 drive bays, leading into 1 240mm radiator mounted on the inside front of the case, which would then go to my GPU block, then to my 240mm radiator on the inside top of the case, then to my CPU, then back to my reservoir pump. I think i have all the parts necessary, but i kind of wanted someone elses opinion. Ill get into learning how to overclock later, but right now i want to make sure my cooling system is as effective as it can be. Sorry for the terrible format, im not used to asking for help.
GPU and CPU Blocks
