I am building a new pc very soon (waiting for parts). i want water cooling in my rig for a mild overclock and want to ask a few questions.
1. Is this upgradeable and would you recommend a different set instead?
2. i would prefer to get compression fittings but want to know what you think? (I have heard some bad leak stories)
3. which is the best, a dye bomb, premix or distilled water? (i would like some color)
4. in the haf x there is a fan at the top can i leave it on?
5. with the top fan not cooling the case will the rest of the components be cool enough?
Case- CoolerMaster HAF X
CPU- Intel Core i7 2600k
Graphics Card- Asus GeForce GTX 570 or Radeon 6950(if i can unlock it to 6970)
Motherboard- AsRock Fatal1ty P67
Power Supply- OCZ ModXStream Pro 700w
RAM- G.Skill Ripjaws X Series 4gb x2
HDD- Western Digital Caviar Green 2tb
SSD- OCZ Vertex 2 60gb
Optical Drive- Sony Dvd Burner
CPU Cooling- XSPC Rasa 750 rs360 -
1 x XSPC Rasa Black CPU Waterblock
1 x XSPC RS360 Radiator
1 x CPU Backplate for 1366, 1156, 1155, 775
3 x 120mm Fan
1 x XSPC X20 750 Pump & Reservoir combo
2 x 7/16" Clear Tubing
6 x 1/2" Barb Fittings
1 x 5mm Blue LED
1 x Velcro Mounting Pad for Pump
6 x Hose Clips
1 x 80 - 120mm Radiator Mounting Kit
1 x Thermal Paste
1 x CPU Mounting Kit
3 x 120mm Fan Grill
Extras: Primochill PURE Performance Coolant 32oz : Blood Red
EK PSC 1/4" Thread Compression Fitting for 7/16" ID - 5/8" OD Tubing : Silver Nickel x6
PrimoChill Anti-Kink Coil for 3/4" (19mm) OD Tubing : Black
Additional Details: Looks are important, i am going for a red/black theme.
All answers are GREATLY appreciated!
3 x 120mm Fan
1 x 5mm Blue LED
6 x Hose Clips
1 x Thermal Paste
3 x 120mm Fan Grill
