First Timer Seeking Advice on PC Parts Replacements.
MWurzer
6
Hello. I've been looking at upgrading my PC for a while now. I received it as a gift, and so far have only had to replace the Graphics Card. I'm wondering though if there are some other components I should consider upgrading, and if anyone has suggestions for parts. The specs are..
Power Supply: Antec Earthwatts EA-650W.
Graphics Card: Was a 260 (Now Upgraded to a 760.)
Memory: 3 x 2GB Corsair TR3X6g1333c9.
Processor: I7-920 @ 2.67 GHz.
Storage: 500 GB HHD (I think. I know it's not an SSD.)
I primarily would like to replace the memory as of now. Preferably with 2 x 8 Cards, and preferably Corsair. I don't know whats compatible however, or what has good performance with my current set-up.
I've also read the I7-920 is pretty solid, even though it's a bit older, but I figure getting another opinion might be best. I don't have much computer knowledge.
Any suggestions would be helpful, in regards to any of the components, or possible replacements.
That said, this PC is mostly for gaming, and I'd like to get the most out of it I can. I'm trying to transition to a machine that can handle 144hz. I don't run browsers in the background, or other programs. Usually just the game I'm playing. In addition I won't be doing any Video Editing, Streaming, etc.
Again, any suggestions would be appreciated! Thanks!
(UPDATE - Motherboard)
Oh, right. I forgot about this. Motherboard listed below.
Mobo: Intel DX58So
Thanks for the speedy responses.
Don't get the 16GB.
You're spending an odd $100 on outdated tech that'll barely give you any more performance given your current specs.
More RAM isn't going to solve anything at this stage, put it towards a CPU and GPU overhaul.
What motherboard are you using? This is part you have to worry about most for compatibility.
I run 2 x 4gb in my system and it does a fine job, but definitely with ram prices they way they are now, 2 x 8 would be the way to go. Brand isn't super important, just be sure to do your research and read plenty of reviews. Reliability is the most important thing when it comes to RAM in my opinion.
Your current PC is about as good as it can be.
Your next step is to upgrade the CPU/Mobo/RAM and GPU, stay with this for another year or two or until you have about $400, and then post again.
Not much else you can do to drastically improve the rig that won't end up being a waste of cash given the age of your CPU especially.
Looks like a pretty old board. It supports DDR3 Ram which is probably fine.
You'll need to upgrade your motherboard before you can upgrade to a current gen CPU or to DDR4 Ram.
You can pick up a current gen motherboard for fairly cheap, just keep in mind what you want to do with your build down the line and make sure to you get a board that "gives you room to grow".
But, as the others have said, you can get by with your current cpu and DDR3 ram will work just fine.
Well, I have a large heat sink that blocks the fourth slot. I imagine that's why my uncle didn't put in a fourth stick when he originally built it. That said, I'll probably be using this PC for a year or more still, so I'd like to get the 16GB just so I don't have to worry about it.
I'm just wondering if the Corsair ones I linked would be compatible, or if they would potentially damage the Motherboard?
The two 8GB sticks I linked are at the price range I was expecting, so I don't mind the price really. Just don't have any idea if they'll work without damaging anything. I read some 1600+'s can cause mobo damage if you don't do some sort of manual tuning?
